Removing rear rotors - Quick question
Old Dec 30, 2009 | 06:02 PM
soundmike's Avatar
I can easily remove the front rotors by screwing a bolt through that "access" hole.
And the rear rotors also seem to have an access hole of sorts (covered by a rubber plug that looks like a screw head) -- i've never worked on a car with the type of parking brakes on the G, so i'm wondering:
-- If i can find a large enough bolt to screw through that access hole, will it damage anything behind it? I shone some light through and saw another bolt in there but am unsure of what it does. Whatever is inside will be what the screw i'll drive through that hole will use as leverage to help push the rotor off the hub.
Any help is gladly appreciated.
Thanks.
Old Dec 30, 2009 | 06:40 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
It's pretty easy.
Just put a block of wood against the rotor face & give it a good belt with the hammer.
Do it in a couple of places & it'll pop right off. (same for the fronts)
The hole with the rubber grommet is the access hole to manually adjust the parking brake pads.
also,
A tip for reassembly.
Use two lug nuts to hold the rotor in it's proper place while you install the caliper
Old Dec 30, 2009 | 07:14 PM
soundmike's Avatar
That's it? I'll give it a shot. I'm just afraid it'll be an endless fruitless endeavour of hammering away. (Had the same issue on my old car, eventually just brought it to a brake shop).
Thanks for the tip!
p.s. Hammer at the rotor surface contacting the pads, right? Not the hub?
Old Dec 30, 2009 | 07:30 PM
nghiars's Avatar
^^^thats it. should be very easy.
Old Dec 30, 2009 | 07:42 PM
vp-g's Avatar
I just took my rotor off to try to adjust my e brake after removing the caliper. came off very easy with a few taps. but i don't think that screw is to adjust the e brake where the rubber gourmet is. I turned the screw to adjust my e brake but the ebrake shoe start coming off so i put it back.
Old Dec 30, 2009 | 07:54 PM
soundmike's Avatar
Thanks guys. I hope my rotors aren't too rusted/sealed-in.
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
MikeTanabe
Brakes
Aug 26, 2015 03:02 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
