Will these rims fit?
Old Jan 20, 2010 | 02:21 AM
Defratos's Avatar
You're Despicable
Question Will these rims fit?
Hi guys my cousin has a set of wheels lying about, originally it was for an Evo 10, and now he's selling them I wanted to see if I'd have any difficulty fiting these sizes:
Wheels----------PCD-------Hole------Off set
19x8.5----------114.3-------5---------51
19x8.5----------114.3-------5---------45
19x8.5----------114.3-------5---------38
Same size wheels and tires for front and rear, would this cause me any issues since the G is a RWD?
Old Jan 20, 2010 | 08:40 AM
Defratos's Avatar
You're Despicable
I forgot to mention that I am lowered on JIC Magic coilovers, but only at the min drop height which I think is around 1- 1.5" lower than stock
and I know nothing about offsets or PCD or how these wheels would affect my handling so any help would be appreciated.
Also would it be ok to use the bolts that came with the wheels for the Evo X? or would I need to source newer ones?
Old Jan 20, 2010 | 08:47 AM
soundmike's Avatar
The first two would end up too tucked-in, being lowered would just amplify that issue. My vote would be on the +38 offset, lower even if you can find it.
Those size wheels will be fine, i run the same on mine (except i have a +35 offset) with 255/40 tires and have no issues with it whatsoever.
p.s. You may also want to check the bore size on those wheels to make sure it fits on the G. Might need to get rings if that's the case.
Old Jan 20, 2010 | 09:20 AM
Defratos's Avatar
You're Despicable
humm ok one questino by bore size do you mean the size of the hole that the bolts fit into?
also does anyone know what the standard offset sizes for the Sports wheels on the G are?
Old Jan 20, 2010 | 10:07 AM
GEE35FX's Avatar
No, he is talking about the diameter of the hole in the center of the wheel. It has to slip over the hub on your car. I believe the proper bore size is 66.1 mm. If the bore on his is bigger than you can use them if you get hub centering rings.
If that is okay than the 38mm offset rim is your best fit.
Old Jan 20, 2010 | 10:19 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
^WHS.
Most aftermarket wheels are 73mm hubs & you need hubcentric rings to fit the Infiniti 66.1mm hub.
& I agree the 38mm offset is definitely the best choice of those wheels.
Old Jan 20, 2010 | 11:04 AM
Defratos's Avatar
You're Despicable
ok now does anyone have a linky to where they sell these hub-centric rings? and are they advisable to use? or is it better to stay away from them?
What I mean is would I get any vibrations or bad feedback when fitting the hub-centric rings? as apposed to staying on my OEM wheels?
Old Jan 20, 2010 | 11:08 AM
Defratos's Avatar
You're Despicable
and what's the offset of the OEM 18" sports wheels?
Old Jan 20, 2010 | 11:13 AM
InTgr8r's Avatar
You absolutely need them.
You should be able to source them from any wheel vendor.
Old Jan 20, 2010 | 11:15 AM
InTgr8r's Avatar
Terry's data table has all that info in there.
https://g35driver.com/forums/v36-bra...ims-tires.html
Old Jan 20, 2010 | 12:40 PM
Defratos's Avatar
You're Despicable
Yeah I know I need them , I'm just asking would I be better off getting different rims, ones which don't need the Hubcentric ring for?
because I don't like adapters and stuff being stuck onto the wheels so are they safe? or could they add any vibrations? or does everyone need these hubcentric rings when getting aftermarket wheels?
lol I hope that makes it clearer
Also thanks for the link dude, it's got all the info I need
Old Jan 20, 2010 | 12:47 PM
cremaster's Avatar
i always thought that most if not all aftermarket wheels needed hub centric rings for a proper fit. the rings are really no big deal; just a small, sometimes plastice piece that just fits inside the hub; makes a huge diff in the smoothness of the ride.
Old Jan 20, 2010 | 12:52 PM
InTgr8r's Avatar
^whs; You won't find wheels other than OE that fit w/o rings.
BTW, if you do any track time I prefer aluminum rings like these.
Aluminum Hubcentric Rings
Old Jan 20, 2010 | 01:39 PM
Defratos's Avatar
You're Despicable
Okkkkaaayy thanks guys that makes sense now, thanks
Old Jan 21, 2010 | 08:58 PM
Defratos's Avatar
You're Despicable
Ok slight update guys, I found out the rims are actually 19 x 9" Offset is 25:
19x9 -----------114.3---------5----------25
Now according to the offset calculator I'll get:
Front
Inner Clearance: 1mm more
Outer position: Extended 39mm!!
Rear
Inner Clearance: 19mm more
Outer position: Extended 31mm
Now would I face rubbing issues? considering this will the size for both front and rear? 9" on the front? and dropped on JIC
