Tire Problem
Old Feb 18, 2010 | 08:16 AM
5u30five's Avatar
Tire Problem
i installed new rubber on the rear yesterday...255/40/19 PS2 and the front remains the 235/35/19 i originally had. to make it short, the cluster lit up like christmas tree...slip, vdc off, abs light all lit up. is this due to the width and aspect ratio of the tires i used? advice and opinoins welcome. TIA.
Old Feb 18, 2010 | 12:35 PM
goodtwogo's Avatar
I'd say that's the most likely cause. You're running tire sizes that are over 6% difference in circumference ( per this : http://www.miata.net/garage/tirecalc.html ) which exceeds the tolerance built into the car's systems.
derres
Aug 28, 2015 03:27 PM
Fireman07603
Aug 9, 2015 06:00 PM
Srinidhi
Aug 7, 2015 03:38 PM
wojowojo16
Jul 27, 2015 09:57 AM
Soumilg
Jul 18, 2015 12:33 PM
