GTSPEC Rear Lower and front subframe
Feb 18, 2010 | 10:46 PM
Looking into purchasing a couple suspension pieces from GTSPEC and wanted to get some input on pros/cons and to make sure these will fit the AWD. Here are the two pieces I am interested in.
http://www.gtspec.com/product/gtspec...hape-07-g35g37
http://www.gtspec.com/product/gtspec...niti-g35g37-07
Reply 0
Feb 18, 2010 | 11:58 PM
Check out this myg37 thread by GT Spec rep recommending what to get first and why.
Reply 0
Feb 19, 2010 | 12:04 AM
Quote: Check out this myg37 thread by GT Spec rep recommending what to get first and why.
Thank you!! Looks like I got one right. I just need confirmation on fitment (although i dont see issues). As soon as I get it, im ordering the lower lateral tie bar.
Reply 0
Feb 19, 2010 | 12:17 AM
I believe AWD are pretty much the same as RWD in the rear. The M bar above is actually more curved now (picture is v.1) and should fit more exhausts. Be warned that sometimes it is a good wait to get the "M" brace. I got the M and the rear tie brace last month from HR Autoparts in the vendor section but won't install them until next month when it warms up. Make sure you ask if they have it in stock or what their expected fulfillment time will be. Some people have waited a good 6 weeks!
Reply 0
Feb 19, 2010 | 12:21 AM
thanks...any recommendations on who to go through?
Reply 0
Feb 19, 2010 | 12:36 AM
Riverside Infiniti may be the most reputable vendor.
Reply 0
Feb 19, 2010 | 12:37 AM
thanks for the PM!
Reply 0
Feb 19, 2010 | 06:37 AM
For the front...
https://g35driver.com/forums/v36-bra...braces-xs.html
Reply 0
Feb 19, 2010 | 09:12 AM
Thank you!!
Looks like I am going with just the rear lateral tie bar....
Reply 0
Feb 19, 2010 | 12:20 PM
Quote: I believe AWD are pretty much the same as RWD in the rear. The M bar above is actually more curved now (picture is v.1) and should fit more exhausts. Be warned that sometimes it is a good wait to get the "M" brace. I got the M and the rear tie brace last month from HR Autoparts in the vendor section but won't install them until next month when it warms up. Make sure you ask if they have it in stock or what their expected fulfillment time will be. Some people have waited a good 6 weeks!
I was actually told there is no V2. There were plans to make it but never did.
Reply 0
Feb 19, 2010 | 01:00 PM
apparently only the 6pt (1350) and lower rear lie (1087) will work with the AWD.
1349 would fit if I had OEM exhaust...
Reply 0
Feb 19, 2010 | 02:10 PM
I take that back....1349 should fit
I just ordered 1087 and 1349
Reply 0
