just installed some GTSpec braces
Old Mar 8, 2010 | 06:48 PM
bat6wc's Avatar
np! now someone sell me their OEM rear sport sway!!
Old Mar 9, 2010 | 01:39 AM
Q8y_drifter's Avatar
i would if i wasn't overseas. Have you tried MyG37?
OT, does the 370Z use the same sways?
Old Mar 9, 2010 | 01:43 AM
bat6wc's Avatar
Yes...I bet the 370 is different. The G coupe rear sway is probably different too
Old Mar 9, 2010 | 05:37 AM
Different in terms of stiffness/thickness or design?
Because Hotchkis sways fit all the V36's and Z34's.
http://www.hotchkis.net/sport_sway_b..._g37s_g35.html
Old Mar 9, 2010 | 06:11 AM
Defratos's Avatar
You're Despicable
why would u want OEM sways?
Old Mar 9, 2010 | 09:53 AM
bat6wc's Avatar
wow, thanks
i want OEM, because I cant get an aftermarket front sway. I dont want the rear to be SUPER stiff and have the front as is.
Old Mar 9, 2010 | 10:49 AM
Defratos's Avatar
You're Despicable
humm what are you running now in terms of sways?
Old Mar 9, 2010 | 10:56 AM
bat6wc's Avatar
OEM AWD sways...the rear is super puny!
Old Mar 9, 2010 | 11:58 AM
Defratos's Avatar
You're Despicable
Ahhhh okay that makes more sense now
Old Mar 10, 2010 | 08:04 AM
mureshan's Avatar
So will the M-brace fit or not?? Any issues with the diff. on X?
Old Mar 10, 2010 | 08:44 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
^ good question....
I just noticed in this pic from Maz.
His rear diff has additional cooling fins under the dif where the M brace mounts.
Maz's ▲with the rear "tie brace"
Mine ▼ with the rear M brace.
This may only be on the hot climate cars, IDK.
I would definitely confirm if you have the cooling fins or not before ordering the M brace.
Old Mar 10, 2010 | 09:46 AM
Intgr8r, is that the updated M brace? Your car is looking nice and stiff there
I noticed that the 370Z has a big brace that joins the rear subframe to the center chassis from factory. Neither the G coupe nor the sedan have this. If Nissan engineers put a brace there then there's probably quite a bit of flex without it. You can see it below painted black.
Old Mar 10, 2010 | 10:50 AM
InTgr8r's Avatar
^ yes, mine is the revised M brace.
Fits the FI exhaust with lots of clearance.
Nice find re: the 370Z brace.
Old Mar 10, 2010 | 01:27 PM
Defratos's Avatar
You're Despicable
When looking at mine last time it looks near to impossible for me to install it and I really wanted the M-brace because it doesn't add any reduction in ground clearance, I'm worried that the 4 and 6 point braces would rub
Old Mar 10, 2010 | 01:30 PM
  #30
Defratos's Avatar
You're Despicable
and dude do your bottom end looks soooo clean compared to mine do u wash yours or something? or is mine just a dirty minger?
