Proper offset for 20" on sedan without BBK
Old Mar 18, 2010 | 08:14 PM
classy37's Avatar
Hi, I'm shopping wheels that are offered 20"x8.5" front 40 offset and 20"x 10" rear 40 offset. My G37 sedan is lowered on Eibachs. Can anyone tell me if these wheels will sit flush with the fender without spacers? TIA.
Old Mar 18, 2010 | 11:01 PM
CalsonicVQ's Avatar
Rear is good....u need 15/20mm spacers in front.
Old Mar 19, 2010 | 01:55 AM
CalsonicVQ's Avatar
Hold on, you have an X? You should go same size all around, not staggered.
Old Mar 19, 2010 | 08:21 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
^whs +1
Old Mar 24, 2010 | 02:10 AM
docaam's Avatar
sorry for being OT
Can I pull these off on S
19 X 9.5 +17
19 X 10.5 +19
Old Mar 24, 2010 | 02:12 AM
kennymo's Avatar
^^^ that is going to be pretty agressive.
Old Mar 24, 2010 | 02:21 AM
docaam's Avatar
I know man but any idea how many mm it will out?
Old Mar 24, 2010 | 03:04 AM
Borna's Avatar
Originally Posted by docaam
sorry for being OT
19 X 9.5 +17
19 X 10.5 +19
The fronts would fit with 225/40's if you're lowered with max camber on the stock arms. (~-2.24*)
The rears you'd need a pull to fit. Even then, if you're looking for a light pull you'd have to run 245/40's to fit them and max out the camber on stock arms (~-3.30*)
Old Mar 24, 2010 | 03:19 AM
docaam's Avatar
Thanks man....225 and 245 would be stretched man on 9.5 and 10.5. I have camber kits front and rear so adjustment is not an issue but cant run that much negative. But I still have a feeling I might be able to pull it off without that much negative camber.
Actually I am getting these offsets on Volks SF Winning bought for my Z but was thinking of installing it here. Lets see where it will go on Z or G.
Old Mar 24, 2010 | 05:34 PM
Borna's Avatar
I can assure you that you won't be able to fit them easily.
I have 20x9.5 +25 245/35/20 (getting 235/35/20) and 20x10.5 +33 255/30/20 (getting 255/35/20) on my car dropped on H&R springs. My front and rear stock camber arms are maxed out at -2.24* and -3.30* respectively.
I'm planning on dropping down to a 235/35 up front cause there's some rubbing up front against the fender bracket. And I need to go up to a 255/35 in the rear cause I'm currently scraping the mid-section of my exhaust on some speedbumps.
The 1" increase in tire diameter in the rear should do it, just hoping the 235/35 which is 0.25" smaller in diameter than my current 245/35's don't cause any scraping issues. (Doubt they will)
If you're willing to go for a pulled fender and stretch+camber then it should look great. Otherwise, throw those on your Z with some spacers to make them more flush and get some wheels with offsets that would fit your sedan comfortably.
Old Mar 25, 2010 | 01:31 AM
docaam's Avatar
thanks man...but my wheels are 19" would that make a difference? with tire width of 40?
Actually on Z also it will be flushed so thats why was thinking of putting these on G
Old Mar 25, 2010 | 05:29 PM
Borna's Avatar
No them being 19's won't make any difference. Check out heyitsalex's car out. He's running 19x9.5 +17 and 19x10.5 +24 with 225/40/19 and 245/40/19 Volk GT-F's IIRC lowered on Eibach's. He said he had some rubbing issues in the rear even after maxing out his front and rear camber on the stock arms so he was planning on getting his fenders pulled.
Your setup will be even more aggressive than that so you'll definitely need some good stretch, camber, and a pull.
Definitely put them on your Z but I say you lower the Z and put some spacers on the wheels to make them more flush/aggressive if that's what you're looking for.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
