any rubbing issues 20"+lowered+ loaded
Old Mar 30, 2010 | 01:02 AM
implicitv36's Avatar
Hey guys a bit of a rim size noob and was wondering if you guys could help.i want to lower the car on eibach springs with staggered 20"s but i always have people in the back seats what set up would you guys recommend where i can lower the car on some staggered 20"s without having to worry about rubbing while having people in the back seat.
Old Mar 30, 2010 | 03:56 PM
JayJay's Avatar
tires should be 245/35/20 for the front 275/30/20 in the back. and unless you travel with elephants in your back seat, you will be fine dropped on 20's!
Old Mar 30, 2010 | 04:13 PM
LightsOut's Avatar
SIETESG
get to know your offsets and widths.
Old Mar 30, 2010 | 04:18 PM
kennymo's Avatar
i cant put people in my back seat. my quarter panels will be sitting on the tire
Old Mar 30, 2010 | 09:43 PM
what width and offsets should i go with for the rear?
Old Mar 30, 2010 | 10:02 PM
Dubi2087's Avatar
It sounds like you will need to roll your fender. Try rolling them first and go from them.
Old Mar 31, 2010 | 03:08 AM
Borna's Avatar
^ 2nd gen sedans come with rolled fenders from the factory.
implicit, you could go for 20x9.5 +35 and 20x10.5 +37 if you're willing to run some negative camber. Check out Alan (BLUESLATE)'s ride, he's running Volk GT-30's with those specs.
IIRC, he said he was running around -2.20* camber in the rear so it shouldn't be too bad for tire wear (as long as you get the toe in spec).
Check out this database for the different options you have.
https://g35driver.com/forums/v36-bra...ims-tires.html
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
Frostbite91
Aug 20, 2015 07:20 PM
Popes
Jul 29, 2015 05:07 PM
