Can I fit G37s wheels on my 08 G35x safely and easily?
Rating: Thread Rating: 4 votes, 5.00 average.
Old Jul 12, 2010 | 10:51 PM
E-Ticket Ride's Avatar
Originally Posted by i3eezenotch
I actually just saw Lexus IS-F wheels and I really dig the way they look...I think they would look good on a blue slate car. Thinking about where i can get some cheap
I doubt you'd fine ISF wheels for cheap. You're better off getting a set of G37C wheels and painting/pc'ing them, kinda like these beauties :
Old Jul 12, 2010 | 10:56 PM
blnewt's Avatar
The G37 Coupe wheels look SOOOOO much better than the G37 sedan rims.
Old Jul 12, 2010 | 10:58 PM
i3eezenotch's Avatar
damn, did you do that^? Man, it's just hard because I need them to be the same size, so I need 4 fronts, I Guess :-/
Old Jul 12, 2010 | 11:04 PM
Got them that way, previous owner had them painted at a shop.
Old Jul 12, 2010 | 11:11 PM
why are they not on the car?
Old Jul 12, 2010 | 11:55 PM
They are, that's a pic when they were delivered.
Old Jul 12, 2010 | 11:59 PM
iiiiiekoiiiii's Avatar
no your car will catch fire.
staggered g37 19s with stock tires will run with AWD without anyproblems. Their dimensions are very good match. Stop being so scared of this. Its not rocket science.
If something is really wrong with you and u want all fronts, Just so u know all rears will work too.
oh yea dont forget to lower ur car.
Old Jul 13, 2010 | 01:40 AM
Mississaugag35x's Avatar
I was looking into getting 19 X 8.5 AXIS shines for my blue slate 07 Sedan (non-staggered fitment - I hear the staggered fitment on a 'x' causes issues).
Here is a photo of the wheel in question
I wonder if I can just get 4 identical g37s wheels somewhere...
I have a blue slate car--anyone have some favorite classy non-OEM wheels they think would look good with it? Not something super chrome or blingy, just classy and nice like the g37s
Old Jul 13, 2010 | 10:40 PM
Just found out that it will be REALLY hard to find all weather tires for 19" wheels so I'm really beginning to consider getting the G37s 18" knockoffs:
Amazon Amazon
I may be able to get them from someone around here for $600 new for a set of 18"x8" wide with +45 offset.
I don't know much about this, but would I have to do anything to make this fit my car besides get smaller profile tires? Also, what tire size would I have to get for these? Would it be the same as the size the G35xs uses?
Any disadvantages towards getting these or can my $600 be put towards better wheels? They weigh 25.4 lbs and are painted cast iron. Also, can I use the stock Infiniti logos on the wheels instead of the "sport edition" logos?
Finally, will it be hard to take off the TPMs from my old wheels to put on these? Am I better off just getting new TPMs?
Thanks for everyone's help!
Old Jul 13, 2010 | 10:59 PM
pattyballs's Avatar
before you do that look into other OEM options. nothing against aftermarket rims but many are much weaker than OEM wheels. check out 350z anniversary rims, you can find them cheap every now and then on my350z.com. but i would deffinitely check out other OEM nissan/infiniti wheels before you go for inexpensive aftermarket rims.
Old Jul 13, 2010 | 11:14 PM
In what way are these aftermarket rims worse than OEM? I think in terms of weight, they are actually lighter than the OEM.
Old Jul 13, 2010 | 11:28 PM
pattyballs's Avatar
They are "sometims", not always, weaker than OEM rims. it will be easier to crack or bend a rim. and the other problem is they will sometimes discontinue inexpensive aftermarket rims making it harder to find a replacement if you are in a situation where you bend or crack a rim. I mean if you were talking about a set of Volk or O.Z rims, sure most of them are usually as strong as OEM rims. Just some of the inexpensive aftermarkets can be weaker.
Old Aug 10, 2010 | 02:27 AM
platinumg35x's Avatar
Originally Posted by blnewt
I had S wheels on my 07 G35 and when the potenzas wore out I put the same size tires on all 4 corners. Here's a link to an old thread w/ pics of the setup. I think the stock staggered sizes are probably within the diameter tolerance that they'd also work w/ the X but I'm not 100% sure about it.
Pics on page 2 of thread.
https://g35driver.com/forums/v36-gen...r-corners.html
did you run into any issues down the road running that setup?
Old Aug 10, 2010 | 10:05 AM
I just put 235/35/19 front and 245/35/19 back on my car Falken 452. So far no issue. The backs are only 10 mm wider and 7 mm taller. So far only about 60 miles on them but no issues. The tires were almost new and the rims only had a bit of minor curb rash on the back. The rims are VIP Furious. Not a high end rim but the rims and tires were $900 so I couldn't refuse. The car drives and handles much better.
Last edited by Mississaugag35x; Aug 10, 2010 at 10:07 AM. Reason: link didn't work
Old Aug 10, 2010 | 10:26 AM
  #30
Austin713's Avatar
Im running 245/40/19 with no issues all around
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
