Can I fit G37s wheels on my 08 G35x safely and easily?
Rating: Thread Rating: 4 votes, 5.00 average.
Old Aug 11, 2010 | 06:17 PM
  #31
Triton3.5's Avatar
That is a sharp sedan!! i wanted coupe wheels also,, actually quite bad,,, but after looking at wheel weights, and cost of factory Infiniti wheels went with aftermarket...
Old Aug 25, 2010 | 11:45 PM
  #32
i3eezenotch's Avatar
Sorry for the late bump, but I was wondering if I would have to do anything special to fit them. I am thinking abotu getting some, but I don't want to worry about dropping the car, or messing with anything at all. I just want to put them on, get the correct tire size to fit, and that's it. Can I do that? Also, can I use the lug nuts from my stock G35x wheels for the new ones? Thanks!
Old Aug 26, 2010 | 12:34 AM
  #33
E-Ticket Ride's Avatar
Yes and yes
Old Aug 26, 2010 | 12:54 AM
  #34
platinumg35x's Avatar
you can but the x with 19s without a drop looks like a monster truck
Old Aug 26, 2010 | 01:08 AM
  #35
Why would it look like a monster truck? Any pix of the X with 19s without a drop? I mean...the circumference will be the same as the stock wheels+tires.
Old Aug 26, 2010 | 02:53 AM
  #36
BTW, you NEED to use the factory nuts on factory wheels for safety. There's a sticky about it, read up on it.
Old Aug 26, 2010 | 03:04 AM
  #37
lefizzet's Avatar
Pretty much this plus a little more fender gap since you're an X. Reason it looks like a monster truck is cause you are now running lower profile tires so less rubber and more wheel. This setup makes the fender gap more noticeable than compared to if you were running oem specs, like a 55 profile tire.
Old Aug 27, 2010 | 02:52 PM
  #38
PG on G's Avatar
^^^^Nice^^^^
Does it have spacers or is that how those wheels fit?
I'm looking at doing same to my IP G35.
Are there more pictures of this car?
Cajuncowboy
Jun 21, 2021 09:47 AM
reavensf
Sep 17, 2015 11:30 PM
kinetek
Aug 3, 2015 04:25 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
rping
Jul 26, 2015 09:53 PM
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
