Tire Rack question
Old Jul 14, 2010 | 10:45 AM
Austin713's Avatar
Originally Posted by BobW
Once the correct pressure has been restored to the tire, the TPMS will reset. No need to "relearn or regesister", if that's what you are referring to, if you have the same sensors. Once your system learns or registers the code for your sensors; the system knows they are there. Just add air to the tire(s) and as long as the pressure is above 28 PSI, you are good to go. The TPMS will need some time to recognize the adjusted pressure, but I've noticed on my G that it takes only about 1/4 for the TPMS to recognize and reset.
Correct! the only time you should have to perform the learning process is when you are using sensors that did not come with the car.
Old Jul 14, 2010 | 11:17 AM
rpm&my_G35's Avatar
BobW - I am aware the original set of TPMS with reset themself. I was referring to a second set of TPMS, for example, on winter wheels. I think Austin and some others found a way to reset the TPMS yourself, at home, so you can switch sets of TPMS back and forth without going to a dealer.
Austin713???
Old Jul 14, 2010 | 11:24 AM
BobW's Avatar
Yup! I've done it and works soooo slick! (see my first post) ;-)
http://myg37.com/forums/d-i-y-instal...-for-free.html
Old Jul 14, 2010 | 11:42 AM
BobW's Avatar
Sorry, RPM. You are correct, Just trying to help Austin and BrianK.
Luisgalvan33
Jul 19, 2018 08:16 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
derres
Aug 28, 2015 03:27 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Luisgalvan33
Jul 28, 2015 05:37 PM
