19x9.5 +12 19x10.5 +12 ???
Fronts would fit with stretched tires and a generous amount of camber but the rears would need some fender work to make them fit.
Might be able to fit it with stretched tires, an aggressive pull, and a good amount of camber dialed in. Widebody would be best.
Like everyone else said you'd have to do some massaging with tire stretching and camber. I think the fronts should fit with a slight stretch while the rears will require a good amount of work.
I'm currently running 9 +20 and 10 +30 on my setup with no problems. Camber settings are at -1.7 and -1.3 for the front and rear respectively. Fronts are out of spec per manufacturers recommendation but rears are in spec (barely!!). Check out "heyitsalex" ride, he's on 9.5 +17 and 10.5 +24 if I'm not mistaken...
bu villain
19 Inch
Nov 15, 2015 09:23 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
