solution to poor tire availability on S
Old Aug 21, 2010 | 02:20 PM
Rollo's Avatar
Is there any reason we couldn't just go up one size in width in front and back? there are 55 choices for 235/50/18 on Tire rack but only 12 for 225/50.
I am thinking of my next set going 235/50/18 front and 255/45/18 rear....thoughts?
Old Aug 21, 2010 | 04:03 PM
lefizzet's Avatar
You don't have to run oem sizes. You can run whatever you want.
Old Aug 21, 2010 | 04:22 PM
thescreensavers's Avatar
Mr.202?
^ yep, but you need to keep it as close to OEM size as possible. For the Speedo and VDC/ABS bits to work.
Old Aug 21, 2010 | 08:17 PM
rustyeleio's Avatar
+1.
Specifically, the front and back diameters can't differ by too much. You could just get new rims and go all the way...245 front and 275 rear.
Old Aug 22, 2010 | 12:16 AM
lefizzet's Avatar
^if you're running 245/35 in the front, 285/30 in the rear is actually closer in diameter/circumference to the front compared to 275/30 but it's not ran as commonly. Reason I chose 285 is cause I have an X so I wanted the specs to be as close to each other as possible.
Old Aug 25, 2010 | 02:38 AM
markk132's Avatar
i'm going to be doing this for next summer. probably gonna try the continental extreme contact dw. and i have a separate set of winter tires for the winter. the conti's are cheap, and their tires are always among the lightest in weight, which i think is often overlooked. plus, the 235/50 and 255/45 sizing will give you a SLIGHTLY smoother ride because of more rubber, will close your wheel well gap SLIGHTLY, and it will give you a little more grip because you'll have more tread on the street. probably won't be noticeable though.
Old Aug 25, 2010 | 03:08 AM
Matchstickman60's Avatar
If your going for a wider size tire, then you should go with 235/45/18 and 255/40/18. It is +10 and -5, which means if you go up from 225 to 235, then your sidewall should go down by 5.
chinee
Jun 10, 2024 07:48 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
derres
Aug 28, 2015 03:27 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
