Is Running?
Old Aug 25, 2010 | 03:05 PM
texas rangers1's Avatar
Is Running?
Is there any downfall from running 30 series tires on all, even when giving them a shot of nitrogen? Well there be big issues with running too low of a profile in the fronts?
Old Aug 26, 2010 | 09:42 AM
soundmike's Avatar
To compensate for overall diameter changes, a lower profile is usually the only way to go... but question is, how big of a wheel will you be using? Recommended size for, say, a 20" rear is in the range of 275/30/20's. I think that's a bit too wide for the front.
You'll be putting extra stress in the steering mechanism from having to move such a wide (and heavy) set-up. It will change the balance and handling dynamics of the car, and hitting any significant debris on the road will likely damage the rim.
Old Aug 26, 2010 | 12:31 PM
The fronts will be 245/30/ 20. Discount tire tells me that their computer show them that 30 series is what comes up recomended...
There are only two cars in the suspension.doc that are running 30 all the way around and now I am a little concerned that I should not run them in the fronts...
Old Aug 26, 2010 | 02:03 PM
lefizzet's Avatar
What are the spec of your wheels? If they're 20x8.5 in the front you should be running 245/35 there's no reason to run 245/30. As for the rears, if they are 8.5 wide also then you are fine running 245/35 all around. If they are staggered and let's say 10-10.5" wide in the back, then you can run 275-285/30 without any problems.
Old Aug 26, 2010 | 03:15 PM
They are 20x8.5 F & 20x9.5 R.
I actually called a different Discount Tire and they said that using 35 series in the front and 30 on the rear would be fine... They also will be selling them $27 cheaper for the set.. I will be getting the Continental Extreme Contact DSW all-season tires.
Old Aug 26, 2010 | 04:46 PM
terfer's Avatar
I'm running 245 35 20 in the front and 255 35 20 in the rear.
Thebaws11
Jul 2, 2021 11:36 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
Thebaws11
Nov 30, 2016 12:54 PM
Vqalexisz
Oct 14, 2015 12:48 AM
n2fooz
Sep 4, 2015 07:46 PM
