Effect of 19" wheels
Old Sep 13, 2010 | 12:45 PM
jcrayamsterdam's Avatar
Question Effect of 19" wheels
Hi All,
Another post with a question. How do 19" wheels effect the G35's handling characteristics? Does it have any negative impacts at all?
Of course there would be more grip but does having large tires like that disrupt the handling setup as Infiniti designed it from the factory?
J
Old Sep 13, 2010 | 12:53 PM
GR6RR's Avatar
might be helpful....
https://g35driver.com/forums/search.php
Old Sep 13, 2010 | 12:57 PM
Originally Posted by Sonny35
I hear you, I hear you. I've been on here for 6 months. I've trolled through every post and visit every day. I've never seen this discussed. This is what I get when I search.
vBulletin Message
Sorry - no matches. Please try some different terms.
Last edited by G35Now!; Sep 13, 2010 at 10:15 PM. Reason: Removing rule-breaking language
Old Sep 13, 2010 | 01:10 PM
Sacch's Avatar
Recently Car And Driver did a test on the effects of bigger wheels.
This should be helpful.
http://www.caranddriver.com/features...sted-tech_dept
Old Sep 13, 2010 | 01:15 PM
Thanks Sacch!
Old Sep 13, 2010 | 01:23 PM
JBF's Avatar
JBF
OP....
19s were offered from the factory...must not cause too many problems if they were delivered as such
Old Sep 13, 2010 | 01:37 PM
LightsOut's Avatar
SIETESG
19's ftw
mine are lighter or equal to oem 18's
Old Sep 13, 2010 | 02:22 PM
GR6RR's Avatar
20s steplip FTW!!!!
Old Sep 13, 2010 | 03:01 PM
LightsOut's Avatar
SIETESG
19's
step lip..
ha!
Old Sep 13, 2010 | 09:04 PM
So the reason I asked in the first place was because I was thinking about getting some G37 coupe 19" put on. I didn't want to sacrifice performance and ride for looks.
Based on that C&D article, 18's may be better for overall performance. My personal assessment aside, has anyone ever seen 18" replicas of the G37 19" OEMs?
J
Old Sep 13, 2010 | 10:52 PM
JBF's Avatar
JBF
^ no
just get the 19s...you wont be disappointed
Old Sep 13, 2010 | 11:18 PM
Neu Era's Avatar
No more than 19's.
Old Sep 20, 2010 | 06:48 AM
celwin's Avatar
At what stage do after market wheels begin to affect wheel bearings? Is there a magic weight that you have to begin to worry that the wheel bearings being affected?
Old Sep 20, 2010 | 09:45 AM
AesonVirus's Avatar
Take a close look at that chart.
They assume that the 19's are heavier than the smaller wheels but I know my 19's are lighter than the OEMs.
They also have different tire sizes which cause the speedometer to be off. I chose a tire that kept the same exact outside diameter.
Larger wheels do not have to mean a decrease in performance
There is a slightly stiffer ride, however. This again depends on your choice of tires.
Old Sep 20, 2010 | 09:55 AM
da mayor's Avatar
my 20's feel close to the same as my OEM 18's... i also went with a stretched tire (245/30/20 front and rear) vs going wider tires which keeps the weight down a bit as well
