19x9.5+ 22
Old Jan 12, 2011 | 10:22 AM
implicitv36's Avatar
19x9.5+ 22
I was looking into buying a set of Wheels for my S sedan and was wondering if anybody knew if 19x9.5 would fit on all corners with no issues.
Old Jan 12, 2011 | 01:26 PM
bluedevils95's Avatar
I don't know much but you might be pushing it or you might have to get your fenders pulled. You can always do a test fit to find out. I have +27 all around and got my fenders pulled about 3 inches.
Old Jan 12, 2011 | 04:12 PM
any pics?
Old Jan 12, 2011 | 05:45 PM
lundy's Avatar
negative camber and tire stretch
Old Jan 12, 2011 | 05:55 PM
CandlestickPark's Avatar
ill Sedan
^+1, You could fit those no prob with the proper tire size. How low are you?
Here is lightsout's ride for reference. His rears are 7mm more aggressive than you are contemplating. His fronts are 6mm less aggressive than what you are contemplating.
8.5 +15 235/35/19
9.5 +15 245/35/19
Yoshi your rears are 10.5s, you are running fat tires (275/35) and not a ton of camber that is why you needed your fenders pulled.
Old Jan 12, 2011 | 07:46 PM
wow! you know my car better then me. lol. I need to learn more!
Old Jan 12, 2011 | 09:23 PM
way_boy's Avatar
yea fit in without any problem.... unless u wanna run some fat tires... u can even fit in 255 to make them best flush^^
cheersss
Old Jan 14, 2011 | 12:14 PM
At the moment im lowered on eibach springs but i plan to go with coils later.
Old Jan 14, 2011 | 01:29 PM
E-Ticket Ride's Avatar
Why would you want a 9.5 in the front?
Old Jan 19, 2011 | 01:23 PM
going with a lipless rim so want a nice concave look to it.
Old Jan 30, 2011 | 08:27 PM
SN00P's Avatar
CLUB MODERATOR
im about to run a 19x9.5 +22 front on my sedan and you can see pictures.. you have to be low and stretch tires are a must also i have my front fender pinched flat and faired a tiny bit
FRONT jack up ...
FRONT fully compressed at 24.3/4'' ground to fender but ill be around 24'' when my tires are on
Old Jan 30, 2011 | 08:35 PM
4DGS's Avatar
That's really just a flush set up imo, you won't have fitment issues at all.
Roll front and back, 255/35 and allow natural camber on say a 2" drop.
Old Jan 30, 2011 | 08:46 PM
SN00P's Avatar
CLUB MODERATOR
thats what im aiming for is a decent flush set up .. ill go more aggressive later on :-) and im going with a 225/35 now so when the time comes to go a little more aggressive ill have the tires to do so ...
Blain with a 225/35 +22 front what should my fender to ground be to have a little flush going on ?
Old Jan 30, 2011 | 09:00 PM
4DGS's Avatar
It's never about fender to ground, IMO always just slam the **** outta the car. If you say you're going 24" even then that will do it. Just lower it enough to tuck tire and you'll be good to go.
You picked a more aggressive stretch for more than one reason (rear fender, future and look)
Old Jan 30, 2011 | 09:09 PM
SN00P's Avatar
CLUB MODERATOR
^^ correct blain i did for a reason but the OP doesn't need the same tire ill need im just picking up general UHP right now even tho the run large but i just snagged a super deal lol the rears ill keep around 24.5 maybe a tad lower
