Camber Kit for 2008 G35x on H&R
Old Jan 17, 2011 | 02:08 PM
lundy's Avatar
I have been searching and I'm struggling to find a definite answer on what alignment kits are being used for a setup like this. Any advice would be appreciated.
Old Jan 17, 2011 | 06:18 PM
mishmosh's Avatar
H&R drop is pretty low. You will want front and rear camber kits like those made by SPC.
Old Jan 17, 2011 | 06:30 PM
J2S2M's Avatar
SPC makes front kit for our cars. I am also currently running H&R's on my 08 sedan. I have kit installed in the rear but not in the front. The tire wear is not that bad IMO. FYI I am currently running at L -1.8 degrees and R -2.0 degrees in the fronts.
Old Jan 17, 2011 | 06:52 PM
lundy's Avatar
Thanks for the info. I'm looking to run similar specs for wheel fitment purposes. Would the Eibach products work as well? I believe I read somewhere that SPC made the Eibach stuff?
Old Jan 17, 2011 | 07:07 PM
J2S2M's Avatar
SPC and Eibach are the same products.. they rebranded as Eibach
My rear kit is the Eibach kit w/ the toe bolts
Old Mar 8, 2011 | 12:49 PM
lundy's Avatar
Sorry to bring back this old thread. Picking up the rear kit this week. Did you need anything for the front? Or just the toe bolts and camber arms for the rear? Also if you know what was the natural camber in the rear with the H&R's?
Old Mar 8, 2011 | 01:00 PM
J2S2M's Avatar
I currently have just the rear kit. It would be an added bonus to have the fronts but I actually got decent mileage on my current set of tires. So I think I will just skip the front camber arms. 6 As to your question about the natural camber on the H&R drop for the rear, I am not sure about because I installed my kit at the same time when I installed the springs. My guess is that it would naturally be around -2.5 degrees or so in the rear w/o a camber kit.
Alex Koss
Oct 29, 2021 12:53 PM
socalg35x
Aug 7, 2015 09:36 AM
rping
Jul 26, 2015 09:53 PM
richmc
Jul 26, 2015 08:13 PM
nascarbuff17
Jul 16, 2015 10:23 AM
