Thoughts on 19x8.5 et41 and 19x9.5 et49?
Old Feb 4, 2011 | 05:26 PM
JawKnee's Avatar
A friend of a friend is selling a set of HREs for a really good deal, but I don't know what to make of the fitment. My '08 S is currently on stock suspension but I would most likely be lowering it with a set of KW V3s.
Any thoughts on the fitment?
19x8.5 et41 shod with 225/35 and 19x9.5 et49 shod with 265/35.
Old Feb 4, 2011 | 05:36 PM
gary c's Avatar
By ET if you're refering to the offset those wheels won't work without fat spacers which aren't a good idea. Shop around and find wheels with no more than 24 and closer to single figures especially if you intend to do the wheel-tuck thing.
Gary
Old Feb 4, 2011 | 05:37 PM
JawKnee's Avatar
Originally Posted by gary c
By ET if you're refering to the offset those wheels won't work without fat spacers which aren't a good idea. Shop around and find wheels with no more than 24 and closer to single figures especially if you intend to do the wheel- tuck thing.
Gary
Thanks for the prompt feedback Gary! That was my initial suspicion as well.
Old Feb 4, 2011 | 08:01 PM
lundy's Avatar
I don't think they will be that bad. And they'll def work w/o spacers but will be a little tucked. If you want an aggressive fitment then go in the 20's for offset. Here is a member's car running 10's in the back with a +48 and the fronts are a 8.5 with a +37 I believe.
https://g35driver.com/forums/media-s...007-sedan.html
Old Feb 5, 2011 | 08:20 AM
soundmike's Avatar
Compared to your OEM sport wheels/tires:
Front:
When speedometer reads 60mph actual speed will be 56.3mph: 6.2% slower.
Suspension: 100% clear (leaves even more room than OEM)
Fenders: Package will stick out 4 mm (0.2'') farther. Acceptable for most cars.
Wheel wells: 100% clear (leaves even more room than OEM)
Rear:
When speedometer reads 60mph actual speed will be 59.3mph: 1.2% slower.
Suspension: Package is 9 mm (0.4'') closer to suspension/brakes components. Acceptable for most cars.
Fenders: Package will stick out 11 mm (0.4'') farther. Acceptable for most cars.
Flushness-wise, you'll come out slightly better than the OEM set-up. If anything, you should be more concerned about how short that front tire is. If you drop it, the tire/wheel will tuck-in further depending on your camber settings.
Duffy25
Accessories
Oct 12, 2015 01:45 AM
dseet
Oct 11, 2015 12:40 AM
gqraverice
20 Inch
Sep 29, 2015 05:39 PM
Jay123
Sep 28, 2015 08:42 PM
wow600rr
Sep 28, 2015 11:50 AM
