Tire Replacement 2008 G35 Sport
Old Feb 12, 2012 | 08:30 PM
  #31
vqsmile's Avatar
Originally Posted by lifted-d
I th
Old Feb 12, 2012 | 08:35 PM
  #32
lifted-d's Avatar
Lol sorry phone..... I think they were 45 series for the 255. I'll check tomorrow. Thier is a speedo error of 4.5% so if I'm do
Old Feb 12, 2012 | 08:36 PM
  #33
lifted-d's Avatar
Ack! Indicating 100 I'm actually doing 96...
Old Feb 12, 2012 | 09:05 PM
  #34
vqsmile's Avatar
Well, I think the speedo error is actually one of the lesser concerns I see for this setup. If those fronts are indeed 45 series, the the diameter differences between front and rear are substantial; like 1.4" difference! There's no way the VDC will not go into spasms with a setup like that. If they are 40 series in the front, then the front/rear difference drops down to a more manageable 0.4", but then that just aggravates another issue you've got....
Your front rims are 7.5" wide, but . . .
The rim width range for a 255/45 = 8.0" - 9.5", with a "normal" width of 8.5".
The rim width range for a 255/40 = 8.0" - 10.0", with a "normal" width of 9.0".
And ...
Your rear rims are 8.5" wide, but . . .
The rim width range for a 275/35 = 9.0" - 11.0", with a "normal" width of 9.5".
SO basically, your tires are too wide for your stock rim sizes. They may fit, but not well, and certainly not for necessarily better handling than a properly sized tire (narrower) tire on the same rims. Think: "muffintops" or you might want to consider some wider wheels.
Just sayin
Old Feb 12, 2012 | 09:15 PM
  #35
lifted-d's Avatar
Ya I read all about that, but mounted them anyway. They were initially to see how big I could go with rubber, but once mounted they are a great fit. Not saying its optimum but it will do for now. Wider rims are in the future. the tires look good, a square sidewall and flat tread area...muffintopness is not a problem, and i detest stretched rubber, prefer my rubber to be wide as or wider than my rims, for rim protection i daily this and may buzz a curb now and then when this does happen i'm like honeybadger i don't give a shiz...(:
update to my surprise they are 245/45 18 in the front, not sure why i thought they were 255....mind gap lol my vdc never acts up unless i provoke it too.
Old Mar 2, 2012 | 04:01 PM
  #36
dimsler's Avatar
i was thinking of tossing my rear tires to the front and mounting 265/40/18 rear, i remember reading pirelli p-zeros will do 265/40/18 on a 8.5 according to there fitment guide. I figure as long as they a firm sidewall?
Old Mar 2, 2012 | 04:17 PM
  #37
vqsmile's Avatar
Why does everyone like to go with muffins? Is it purely for looks? They handle worse than narrower tires on the same rims. Rim protection is better, but handing is definitely worse.
Old Mar 2, 2012 | 04:30 PM
  #38
dimsler's Avatar
I live in a large city, I parallel park once or twice a day, %99 of the time I won't hit a curb, but one day it happens and totally scratches it up. As for muffin tops, going from a v35, alot of the auto crossers ran 275/40/18 on the stock 18x8s didn't look muffin topped at all, but that all depends on tire, and wheel lip. As long as the tire is nicely squared, handling should improve due to the larger contact patch.
Old Mar 2, 2012 | 05:27 PM
  #39
vqsmile's Avatar
All other things being equal, lots of folks who track their cars (not 1/4 mile) will report faster lap times with a tire that is either just at, or slightly narrower, than the optimum for a given rim size. In this case, bigger is NOT always better. A slightly narrower tire will have less sidewall flex than the wider tire, and hence, will hold a line better. Track times don't lie.
Old Mar 2, 2012 | 08:30 PM
  #40
lifted-d's Avatar
True track times don't lie, but the bigger meats on the rear have tamed the wheel spin exiting corners, and it's tougher to get abs active under hard braking. I doubt that my car will ever see a track. I find my current tire set up to be substantially better for aggressive street use than stock.
Old Mar 2, 2012 | 11:02 PM
  #41
dimsler's Avatar
Could you post some pics for us of the front and rear tires and wheels? I would love to see how they look.
Old Mar 2, 2012 | 11:17 PM
  #42
lifted-d's Avatar
Yes I was thinking I need to do that, though we still have a couple months of winter here, and my snows are on at the moment. Maybe I'll spin one side on for pics on my days off.
Old Mar 8, 2012 | 12:11 PM
  #43
lifted-d's Avatar
so first two are of loose rears, then rears mounted car on ground, then two shots of front loose, and one of front mounted. hope this works?
Last edited by lifted-d; Mar 8, 2012 at 12:19 PM. Reason: photos not loading correctly
Old Mar 9, 2012 | 03:34 PM
  #44
dimsler's Avatar
much thanks for the pics!
Old Mar 9, 2012 | 07:55 PM
  #45
lifted-d's Avatar
no problem, i think i'm gonna try some 255 up front yet. i'd like to put 285 in the rear but the price jump is quite big and i am pushing it a little on these rims anyway. though i think its worth noting that mm are tiny units and while rims are measured in inches tire width is mm. if you look at a ruler 30 mm is just over an inch, so even on my rears i have only pushed the base of the tread out 15mm or approx 5/8 of an inch per side, and they don't sit as wide and fat as they would on wider rims but the meat on the ground is greater even so..... i used chalk on the corner tread to determine an appropriate air pressure.
