I am running out of ideas of what my vibrations are caused by on highway
Old Apr 1, 2014 | 12:59 PM
  #241
My Key's Avatar
Could be the wheel bearing. have you checked the lower control arms to make sure its not bent and/or the bushings f'ed up?
Old Apr 1, 2014 | 01:49 PM
  #242
eagle3000's Avatar
I did check the arms on the lift even with measuring tape, I couldn't see any difference with either one of them
What do mean by bushings fed up?
Old Apr 1, 2014 | 02:00 PM
  #243
My Key's Avatar
fu*ked up. lol
something like this:
Old Apr 1, 2014 | 02:24 PM
  #244
eagle3000's Avatar
Lol...That also looks good
Old Apr 1, 2014 | 02:26 PM
  #245
My Key's Avatar
any way it might be a loose bolt?
Old Apr 1, 2014 | 08:45 PM
  #246
Urbanengineer's Avatar
Send that over to Frankie haha.
Old Apr 1, 2014 | 10:04 PM
  #247
eagle3000's Avatar
Lol
That wouldn't be cool, There was guy with the same problem on this forum not too long ago I hope didn't do that...
The only bad thing about it I no longer have warranty on the car.
I'll wait out a little more, one of these dealership had to dealt with this problem before, the only thing though they might have changed out everything on the front end until the problem was gone ��
Old Apr 1, 2014 | 10:06 PM
  #248
eagle3000's Avatar
@My Key your top pic where on the car is that?
Old Apr 1, 2014 | 10:48 PM
  #249
That picture is either a lower control arm or a compression rod. Not 100% sure.
Old Apr 1, 2014 | 10:59 PM
  #250
eagle3000's Avatar
Where did you get it?
Old Apr 1, 2014 | 11:05 PM
  #251
eagle3000's Avatar
Now I know how you got that name "Urbanengineer" Lol .... :BOUNCE
Old Apr 2, 2014 | 12:03 AM
  #252
http://www.nicoclub.com/FSM/G35/
Follow the link and look at the suspension section of the factory service manual (FSM). You will see the front suspension laid out in "blown out" view and you can clearly see which one is that talked about here.
And thanks.
Old Apr 2, 2014 | 09:42 AM
  #253
LoSt180's Avatar
Originally Posted by eagle3000
A mechanic from the dealership says it could be the wheel bearing , but my question is why is it not constant?
Why only when you make right turns at 45MPH and up?
There's a TSB about wheel bearings after impacts in a accident. So could be the wheel bearing is bad. I had a wheel bearing go bad on our Armada and it only made noise when turning/lane changes. It wasn't the normal whirr/rumble sound associated with bearings going bad.
Old Apr 2, 2014 | 03:28 PM
  #254
eagle3000's Avatar
Whats the cost on a pair of wheel bearings and do you of to press them?
Old Apr 4, 2014 | 02:31 AM
  #255
Ozzybrembo's Avatar
Baddddd Wheel bearings!!!!!!
