Spacer recommendation needed!
Old May 20, 2011 | 05:50 PM
Judono's Avatar
Originally Posted by vqsmile
That's a bit of an absurd question though; of course a setup that would at least bolt down properly is safer than one that wouldn't even sit flat. But that really assumes that the wheels you have are the only possible wheels that can be used. A different set of wheels (with reliefs if need be) used with a bolt-on spacer is still better than extended studs with a free floating spacer. As I said before, I recognize that I am a purist about this, and I know people can and do "get away" with using those other spacers all the time; I'm just saying it isn't right and there is a distinct structural difference.
Awesome, thanks for the help. I was originally going to go with a 20mm spacer based on your expert recommendation, but now that you think that the 10mm with extended studs is safer I will go with the that. Thanks again for the help.
Old May 20, 2011 | 07:09 PM
vqsmile's Avatar
WOW...
First of all, I think you totally missed my point here. I would NOT advocate using 10mm free floating spacers over using a bolt on 20 mm spacer. That is not exactly what you asked. I think I mentioned the question was absurd, so how did you arrive here? (frankly, it's so twisted that I'm wondering if you're just messing with me now)
Second, I am NO expert by any means. Please do not make any decision based merely upon my understandings. I mention it only so that you've heard it, are aware of other considerations, and then can go research it on your own and make your own decisions.
Old May 20, 2011 | 07:31 PM
machochino's Avatar
LOL, that's ok. It just takes some a little longer than others. Let it be. Let's not be condescending!!!!
Old May 20, 2011 | 07:42 PM
Judono's Avatar
Now I'm completely confused. Here is my situation, my buddy lent me his ichiba v2 20mm spacer to place on with my new SSR wheels. However they do not sit properly because the SSRs are flat with only 5 holes with hardly any space to accomodate the oem studs sticking out. I cannot torque the wheels down to proper specs. I do have a set of 10mm with extended studs and they sit fine but do not give the look I want. I figured the 10mm was safer but when I ran across this thread and your replies I started to second myself. I guess I could pickup a set of 20mm with extended studs. Thanks again for the help.
@machochino
Thanks for the support!
Old May 20, 2011 | 08:20 PM
vqsmile's Avatar
@machochino
First, my apologies to Judono, I did not intend to be condescending, and I'm sorry if I came across that way. When I commented that your original question was absurd, I meant it in the sense that it was illogical, unreasonable, unsound, incongruous, etc. (the definition of absurd); it made no sense to compare the two situations as you proposed them. It would be akin to asking whether three lugnuts on a wheel would be safer than using 5 lugnuts that were stripped. Of course they would, but if you compare 3 lugnuts to 5 lugnuts that are in proper shape, as a general rule, there isn't really any question which is best.
Anyway, back to your situation. I think if I were in your situation and I had a set of wheels without any reliefs on the backside (for the tips of the studs which are sticking through the spacers) then I'd consider the following options:
1) replace the wheels with some that will fit
2) replace the studs with a slightly shorter length
3) grind down the protruding stud tips
Options 2 & 3 assume that all care would be taken to ensure the stud retains enough protrusion beyond the bolt-on's nuts to retain full strength.
Follow manufacturer's recommendations or look at these links for reference:
http://www.eng-tips.com/viewthread.cfm?qid=116613
http://www.eng-tips.com/faqs.cfm?fid=1331
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
deathsupport
Canada
Aug 2, 2015 10:13 AM
Detailed Image
Jul 29, 2015 08:42 AM
Soumilg
Jul 18, 2015 12:33 PM
