Replacing a tire because of bulge - advice?
Old May 14, 2011 | 08:03 PM
adam_g35x's Avatar
I just got my 07 G35x last weekend and noticed this morning that there is a bulge (Michelin Pilot Sport A/S). The tires look brand new, couldn't be older than 6 months ~5k miles. I took it back to the dealer I bought it from (BMW) and they said that it wasn't noticed in their inspection and that it appears to be caused by a pothole since there was a mark on the rim. If I had noticed it earlier in the sale (2 day warranty), maybe they could have done something. So, basically, they're saying it was my fault some how. OK. I called Michelin, they said if it were caused by manufacturer defect, they would cover a % of the replacement (depending on tread depth).
Three scenarios;
1. It's a small bulge, roughly the size and depth of the back of a teaspoon. Should i just keep an eye on it and avoid potholes with this tire at all costs, but still drive on it? (you are not liable for your advice in this scenario, i understand the consequences)
2. Just replace it, take it to be inspected and by chance it'll be a manufacturer defect.
3. Since the tire is like $225 in my area, consider "matching" the tread with a more economical tire (Suimoto/Falken/Goodyear)?
Thanks in advance.
Old May 14, 2011 | 08:16 PM
E-Ticket Ride's Avatar
A buldge on the sidewall (if its there) is bad news, get it replaced
Old May 14, 2011 | 08:26 PM
the_sedan's Avatar
normally bulges only happen when you hit something.....scuff marks on the tire will be evident. replace it.
Old May 15, 2011 | 10:45 AM
adam_g35x's Avatar
What do you guys think about matching tread patterns with a different tire brand?
Old May 22, 2011 | 04:22 AM
izzueeek's Avatar
I am in the same situation. I bought these continentals used with 90% thread left. The weird thing is I curbed it by accident, but it wasn't bad at all. A few days later when I lifted up the car I found a bulge on the inner sidewall of the tire and not the place where I curbed. Anyone have any idea why it did that?
That's so weird. I think I need to replace it as well.
Old May 22, 2011 | 02:57 PM
vqsmile's Avatar
It was probably there from before (a good reason to be VERY careful when buying used tires!). I would definitely replace it too. At least with 90% tread left, your replacement will blend well with the remaining tires.
vitamin.v
Nov 7, 2019 06:10 PM
35reilly
Drivetrain
Aug 6, 2015 12:40 AM
itschuckster
Jul 25, 2015 08:07 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
nascarbuff17
Jul 16, 2015 10:23 AM
