ALL Lowered AWD people - Need alignment help
Old Apr 2, 2011 | 02:24 PM
Lucky_One's Avatar
Originally Posted by acm25
I'm in the same situation as the OP. X with Eibach PK and Eibach rear camber kit + toe bolts. They were only able to get my camber to -1.5 in the rear while keeping toe in spec.
I'm wondering now if the shop that installed my camber kit enlarged the holes for the toe bolts? Is it possible that even with the toe bolt kit properly installed that you still can't get camber into spec?
thats what im going to find out. Im hoping that the shop didnt enlarge the hole and all i would have to do is enlarge the hole and hopefully get the my camber back to spec.
Old Aug 30, 2011 | 07:37 PM
MPG35fiend's Avatar
Omg. Im having issues with my alghnent also!
i have an 04 G35X lowered in bc coils and rolling on 18x8.5 all around. i bought the eibach spc rear camber kit..... my toe is in spec but the camber is at -2.5/-2.3. <--- is this bad?
now my MAiN concern is the front camber is -2.7/-3.4!!??!! now what i need to know is if the RWD and AWD front control arms are the same?? i need a camber kit but all the vendors cant tell me if the EIBACH ALiGNMENT PRO KiT will fit the AWD.
someone please tell me the answer to this problem.
Old Aug 31, 2011 | 02:45 AM
harp00n's Avatar
your tires will die very soon, sorry
the camber shouldn't exceed -2
Old Aug 31, 2011 | 08:17 AM
MPG35fiend's Avatar
do you know if the front camber kit on the RWD fit the AWD?
Old Nov 3, 2011 | 12:25 AM
2006g35xsilver's Avatar
I put in SPC kit 72125 on my 2006 G35X last Fri and it fits like a glove. I'm guessing the V36 is the same for 2WD/AWD as well for the control arm (part 72130).
Alex Koss
Oct 29, 2021 12:53 PM
rezendvous420
May 31, 2020 01:26 PM
smokey2
Aug 14, 2015 03:07 PM
wuppiedog
Aug 7, 2015 11:16 AM
itschuckster
Jul 25, 2015 08:07 AM
