Tanabe NF210
Old May 18, 2011 | 11:37 AM
Judono's Avatar
Too soft? Too much rebound? Nope. I had the springs installed along with sway bars and the ride was way better than stock. My buddy drove it and he commented that this was the way the car should have come from the factory. I do wish the front were slightly lower, but as it stands right now, I don't have to worry about most dips, bumps, and driveways. I did scrape my exhaust once but that was mostly my fault. Anyhow, good luck with the install and post up those toe numbers peeps.
Old May 18, 2011 | 12:30 PM
Christopher112's Avatar
Do you have an X or RWD? Did you use a spacer/isolater in the rear to balance out like some have?
Old May 18, 2011 | 01:29 PM
Judono's Avatar
Ummm... yeah. I have a rwd blue slate sedan sitting on 19x8.5 +36 19x9.5 +38 AME Shallen MX wrapped in 245/35 275/30 dunlop sport maxx tires dropped on tanabe nf210 with upgraded sway bars and strut bar.
Old May 19, 2011 | 06:53 AM
celwin's Avatar
I'm not an expert, but that doesn't seem too bad. I would be more worried about your toe numbers. My G is dropped on these same springs and haven't decided if I want to install toe bolts before I get my alignment.
Celwind, Black Sedan what were your toe numbers before and after the alignment? Were they able to zero it out?
Old May 19, 2011 | 12:10 PM
Judono's Avatar
Thanks for the info man. Toe at max specs. both front and rear. Hmmm...
prinny
Nov 22, 2015 11:07 PM
alessandro
Oct 8, 2015 09:29 AM
ChickenTendrs
Sep 16, 2015 01:10 PM
Moskvitch
Sep 14, 2015 10:15 AM
