Front camber kit w/ coilovers
Old Apr 30, 2011 | 11:50 AM
v36sedan's Avatar
I'm looking to purchase BC BR coilovers this coming week and was wondering if the the front camber kit is needed?
Old Apr 30, 2011 | 12:56 PM
gannicus's Avatar
This topic Has been covered. You can get it to oem spec you will need camber kit in the rear with toe kit. Remember to roll your fender before drop it.
Old Apr 30, 2011 | 01:29 PM
v36sedan's Avatar
I've read it is needed with springs. But most coilovers have a camber adjustment on the top mount of the strut and was wondering if that is enough to get it into oem spec or if the spc is still needed. I know the rear is needed.
Old May 1, 2011 | 08:37 AM
soundmike's Avatar
The BC's have no built-in camber adjustments. The need for a kit is highly dependent on how low you'll be. I'm dropped minimally and camber is slightly off, but Toe is well within spec. I have not seen any unusual tire wear as a result of this. Granted, i do check pressures almost weekly, and rotate religiously.
Old May 1, 2011 | 10:35 AM
v36sedan's Avatar
Looking into getting Megans coils instead. If anyone is using these chime in. Wondering if you got your front camber back to spec with the top mount adjustment? Or if if a front camber kit is still needed?
Old May 1, 2011 | 05:11 PM
soundmike's Avatar
I don't think you can get a CO with top adjustments because of how the struts are mounted.
Old May 1, 2011 | 05:40 PM
v36sedan's Avatar
According to Megan they come with top mount camber adjustment.
Old May 1, 2011 | 05:57 PM
soundmike's Avatar
If that's the case, that's good. Although i honestly don't know how they're able to do that without modifying the strut tower.
Old May 1, 2011 | 06:37 PM
v36sedan's Avatar
I get what your saying. Hopefully someone with them will chime in
Old Dec 17, 2017 | 12:49 PM
gsoto999's Avatar
Bumped!!!!!
Old Dec 17, 2017 | 01:45 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
What exactly are you bumping? Anything lower than about -3/4" from stock will require a camber kit?
Picture Share
Feb 4, 2018 12:41 PM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
9tray turbo
Sep 29, 2015 10:22 PM
