Car Sways With New Wheels? Help Please
Old May 24, 2011 | 10:32 AM
RelliKg35's Avatar
Hey guys i lowered my car with the H&R's and the drive was fine with the oem 18s. Just need to get an allignment. Then i swapped my buddys 20x8.5 MSR 093 wheels with a +24 offset all around onto my car. When i would drive on the freeway and make quick motions it felt like the wheels were going to seperate from the car. Ended up that the Hub size on the wheels was 82 and the g35 is 66.1 so i got some hub rings and that fixed it for the most part. But still on uneven ground the car will drift away with the road. It never did that with the oem 18's. Any suggestions on what it may be? Im going to get an alignment and rebalance the wheels to see if that helps but not sure what else it could be.
Old May 24, 2011 | 11:48 AM
E-Ticket Ride's Avatar
If by "drifting away with the road" you mean that tue car follows the lines/grooves of the road (meant for traction), then that's "tramlining" and that's attributable to the tires.
Old May 24, 2011 | 01:10 PM
vqsmile's Avatar
Since the hubcentric rings got past you the first time, I'm gonna suggest you make sure your lugnuts are the correct type for the wheels you're using. Other than that and as mentioned above, tramlining is a distinct possibility.
Old May 24, 2011 | 04:42 PM
RelliKg35's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...7365&viewitem=
these are the lugnuts that i am using on the car...are they the wrong kind?
Old May 24, 2011 | 05:08 PM
vqsmile's Avatar
IDK, is that type what is appropriate for "my buddys 20x8.5 MSR 093 wheels" ??
reference: http://www.brandsport.com/howdoifirilu.html
rezendvous420
May 31, 2020 01:26 PM
Sepsis
Feb 12, 2020 02:05 PM
itschuckster
Jul 25, 2015 08:07 AM
vstypicals
Jul 20, 2015 10:55 PM
realtalk21
Jul 20, 2015 09:07 AM
