19x9.5(20m off) 19x11(18m off) on G35x
Old Jun 27, 2011 | 11:27 PM
Ghost35x's Avatar
I have a 07 G35x, stock suspension.
Can I run 19x9.5(20m off) 19x11(18m off) rims on the awd sedan without any hassle?
I already have 245/40/19 tires for the front in my garage, what size do I need for the rears for this setup to work properly? I want a little width to them, atleast 275 or 285.
Thanks in advance.
Old Jun 27, 2011 | 11:30 PM
4DGS's Avatar
Thanks in advance.
Not gonna happen.
Pick different wheels.
Old Jun 27, 2011 | 11:40 PM
lefizzet's Avatar
Originally Posted by 4DGS
Not gonna happen.
WHS way too aggressive for a 2nd gen without a drop.
Old Jun 28, 2011 | 12:55 AM
OMG35S's Avatar
You'll need to be slammed for those to work..
Old Jun 28, 2011 | 09:26 AM
Ghost35x's Avatar
Can you explain a little more. How will lowering it help them fit?
Old Jun 28, 2011 | 11:01 AM
sunny G-35 NYC's Avatar
To answer your question in a professional manner I would say go do some research about wheels and tires, lowering your car,negative camber, coilovers vs. springs, stretched tire vs. Regular tire. Once you do this I am 100% sure you'll understand how lowering the car helps make them fit. Check out the media share threads in this section and check out the picture share section on the main page you will get your answer
Old Jun 28, 2011 | 01:03 PM
surfjax87's Avatar
Use the lowered with aftermarket rims database sticky to get an idea of what you want to run in terms of offsets. BTW, a 19x11 +18 will stick out about 70mm more than what you have with the stock rear wheels.
Old Jun 28, 2011 | 05:30 PM
Ghost35x's Avatar
Thanks for the feedback. Back to the wheel search.
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
AJC128
Nov 1, 2015 11:55 AM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
Claudiu
Sep 26, 2015 01:04 PM
