20x10 + 35
Old Dec 8, 2011 | 07:12 PM
implicitv36's Avatar
20x10 + 35
does anybody know if i can fit a 20x10 + 35 on all 4 corners on a 2nd gen sedan without major camber.
Old Dec 8, 2011 | 07:16 PM
E-Ticket Ride's Avatar
Why would you want such a wide wheel/tire up front?
Old Dec 8, 2011 | 07:34 PM
want to go with a deep concave wheel. Only other choice is x9 +20 or +35
Old Dec 8, 2011 | 07:37 PM
bluedevils95's Avatar
That is a good but you can always test fix it on your car
Old Dec 8, 2011 | 07:53 PM
cant test fit it buying from a online vendor.
Old Feb 24, 2012 | 05:26 PM
jelloman's Avatar
Any update on this? Anyone else know if that's possible? I am looking into the same set up as well.
OP, did you ever get your set up? Any Problem?
Old Feb 24, 2012 | 05:47 PM
B L U E S L A T E's Avatar
Honda Accord
You can fit 9 +20 up front.
10 +35 is cake.
My front set up is 9.5 +18 with plenty of space and rear setup is 10.5 +25 with also plenty more space to go.
Though, you'd need to carefully chose what tire you want to go with and how much camber you're willing to run.
Old Feb 24, 2012 | 05:50 PM
apexi957's Avatar
Easy setup. You can do +25 easily and some more
Old Feb 24, 2012 | 06:30 PM
nghiars's Avatar
OP-whats YOUR definition of MAJOR camber? 1 / 2 / 3 degrees?
Old Feb 24, 2012 | 06:42 PM
jelloman's Avatar
20x10 +35 all around plus Eibach drop = good to go? I want camber to be as close as factory spec.
Just want to confirm with you guys or those who has experience before I make my purchase. Thanks guys.
Old Feb 25, 2012 | 09:48 AM
EnviedG35's Avatar
Im running 225/50/18 +15 up front just fine. A 275/30/20 +35 will actually put you 1mm further in than what I have, so you should be fine. Im lowered on Eibachs as well.
Old Feb 25, 2012 | 10:53 AM
Hey guys i ended up going with 20x9 + 32 for the front since i couldnt get a definate answer in time.
https://g35driver.com/forums/media-s...new-shoes.html
Old Mar 19, 2012 | 11:41 PM
Fumanchu's Avatar
Will a 20x10 et25 with a 245/35/20 and -2.0 of camber all around fit? I know the back will fit but how about the front?
Old May 11, 2012 | 01:54 AM
anthonychavez's Avatar
Have u tried to put the 20x10+35 in.the front just to see how it would have looked? And if it worked w/o any issues . I want to put 20x10+35 in front!! Test fit it ftw
BlackGee35
Jul 31, 2015 11:04 AM
PIONEER
Archived Sales
Apr 20, 2006 08:30 PM
ttrank
Apr 10, 2006 05:48 PM
mr_ecktid
Nov 10, 2005 05:33 AM
