pls help with coils
Old Dec 14, 2011 | 02:07 AM
GXXXV X's Avatar
pls help with coils
right now im just trying to understand the process of putting them on, but i wont be attempting the install until January.
i want it at max height when i install it, so do i need to adjust the part circled in red? not really sure what that would do, just make the springs harder i guess? (i already have the other adjustable areas at maximum height)
also, for those with BC coils, how much should i lower the front to make it even with the rear when its maxed out?
thanks!
Old Dec 14, 2011 | 03:21 AM
E-Ticket Ride's Avatar
You're only going to adjust preload via the two collars you circled. I don't know if they're set from the factory by BC or you need to do them yourself, but it won't hurt for you to check that.
If they're already set from the factory, all you're going to do is set the height via the bottom collar and you're done.
Old Dec 14, 2011 | 10:50 PM
GXXXV X's Avatar
Thanks, how do I make sure they're both at the same preload, should I measure it or something?
Old Dec 16, 2011 | 12:45 AM
bat6wc's Avatar
very interested to hear your thoughts and get some pics and measurements of the kit at max height.
Old Dec 21, 2011 | 06:10 PM
Racer_X's Avatar
**subscribed**
Old Jan 8, 2012 | 08:29 PM
GXXXV X's Avatar
i finally got around to the install today, very straightforward if you are good at car stuff lol but it took me a good 4-5 hours :P but anyway i decided not to use the spacer for the rear, so at max height without the space there is about 1.5 finger gap rear and max in front is 2 finger gap i did measure before and after so if anybody want to know just lemme know but for now im too lazy... ...about to go test drive on 1 click from soft hehe
Old Jan 10, 2012 | 10:51 AM
GXXXV X's Avatar
After driving about 50 miles my rear is now sitting at 0 finger gap and the front is a 1 finger gap, I will measure it at the end of the week when I go in for alignment
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
DRG35R
Jan 31, 2016 07:14 AM
prinny
Nov 22, 2015 11:07 PM
Rose M
Oct 12, 2015 10:00 AM
Jeff469
Sep 25, 2015 09:28 AM
