Possible issue with fitament on fronts with 18x9.5 et35
Old Jul 3, 2012 | 08:18 AM
bmckenney's Avatar
I am looking at these wheels for a g35X sedan that will be lowered on Eibach pro kits and after searching I was really surprised to read a few posts stating there would be issues on the fronts. But I also read a few other posts where wider wheels and a reasonable amount of offset should not be a concern.
http://forums.beyond.ca/st/356196/fs-enkei-pf01s-sold-/
Old Jul 3, 2012 | 02:33 PM
soundmike's Avatar
I have 18x9.5 +38, or pushed 3mm more than that. With 255/45/18s and camber back on the lower end of the OEM specs, there's room to spare. I'm dropped roughly the same as Eibach's.
With more aggressive offsets, there's a lot more room to spare.
Here are some pics from before the camber kits.
Disclaimer. With the Eibach sways, there was very slight 1-2mm wide rubbing between the inner wheel lip and the protruding portion of the elbow on the sway when the wheel is at full lock to the right.
Old Jul 4, 2012 | 01:53 PM
bmckenney's Avatar
It turns out the seller bought the car with the wheels on already and did not exactly what they were so just measured width with a tape. Checked out the stamping and they are 18 by 8.5 actually. That's good for me.
rezendvous420
May 31, 2020 01:26 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
newg37
Jul 26, 2015 09:32 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
stay_tuned
Jul 21, 2015 07:09 PM
