will these fit?
Old Dec 12, 2012 | 02:44 PM
drcasper's Avatar
will these fit?
Hi guys... I'm planning to buy a set of F14's with the following sizing and I want to know if it will be too aggressive.
F:19x9 +25 (245/35) [semi concave]
R:19x10 +30 (275/30) [deep concave]
I have an 07 G35 Sedan journey w/ eibach pro kit.
Thanks.
Old Dec 13, 2012 | 12:07 AM
blnewt's Avatar
Here's a good calculator, used it recently and ended up w/ perfect offsets for my application~
http://www.myg37.com/forums/tire_rim_calculator.php
FWIW I went 8.5"x20" +40 245/35/20 fronts (tires about 10mm from fender lip since front fenders have less clearance underneath)
10"x20" +45 295/30/20 rears tires about 3mm from fender roll
lowered on coilovers, no gap.
I think you'll need slightly more conservative offsets, might be poking a bit w/ those that you listed.
Old Dec 13, 2012 | 03:30 PM
VMRWheels's Avatar
I think the rears will be poking slightly. We had a sedan running our 19x10 +25 V710s all around with 235s and the wheels were poking out past the fenders.
Old Dec 14, 2012 | 11:26 AM
soundmike's Avatar
FWIW, my old wheels, pictured below, will stick out 1mm more than your rear set. These are with 285s.
Roughtly -2 camber with an Eibach-ish drop.
Old Dec 16, 2012 | 12:31 AM
Kantoklassic's Avatar
Actually in my opinion those are pretty good flush fitment for the sedan. The front I can guarantee you will be okay. Here are some pictures with the OEM 370z Ray wheels. This guy is running the almost the exact same setup you are looking for except his tires are a bit fatter and the fronts are 5mm more agressive. I say if you at least have an eibach drop like this guy, it will be sitting perfect.
09 journey sedan
370z rays forge sports rims.
F 19x9 + 20
R 19x10 + 30
Tires:
F 245/40R 19
R 275/40R 19
Suspension:. Eibach spring
Size:  140.1 KB[/QUOTE]
I say go for it if you are getting a good deal. Post pics up when you are done!
Old Dec 16, 2012 | 12:54 AM
jim9's Avatar
Looks like a good offset and that sedan looks really good!
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
dseet
Oct 11, 2015 12:40 AM
Claudiu
Sep 26, 2015 01:04 PM
