Akebono BBK install clarifcation
Old Apr 11, 2013 | 02:13 PM
BillBradley's Avatar
Working on putting together a Akebono BBK upgrade on my 2008 G35 Journey Sedan. I’ve already been running G37s 19” oem stock wheels for several years so they should clear without any issue. I purchased a set, (front and rear), Akebono used calipers and oem brake lines from a G37S. I also have the bolts and old pads that came with calipers. For the install, I have purchased R1 Concept drilled rotors and Posi Quiet Ceramic pads (front and rear). Not looking to do any track days, just want a little upgrade and mostly for the looks.
I have read many of the post for the Akebono install, but still need to clarify a few things.
Below are a questions I have:
Any problem with running the 19” OEM wheels. I read others use spacers, is this for 18’s?
Dust shields, one post stated the fronts are not that hard to change, but the backs are a PITA, to cut/Trim the back. Best place to buy, (On-line, Nissan or Infiniti dealer)?Comments-
Any issue using the stock brake lines. I know the stainless is a firmer pedal and less flex, and I installed a set many years ago on a Porsche I had, but trying to keep it simple?
What brake fluid are most using? Again no track plans, just due for a change with the install.
Thanks in advance for your input.
Bill
Old Apr 11, 2013 | 10:20 PM
blnewt's Avatar
Send a PM to Soundmike, he'll know what you need.
Wheels shouldn't be a problem since they're the 19" from an S. If yo9u have any doubts you can pull one and use these F&R templates
http://www.conceptzperformance.com/i...nttemplate.pdf
http://www.conceptzperformance.com/i...artemplate.pdf
You'll need new brake lines, unless you meant the stock lines that came w/ the Akebonos, not the lines that are currently hooked to your non-S setup.
Old Apr 12, 2013 | 09:21 AM
blnewt,
Thanks for the response. I'll pm Souondmike for his input and yes I did mean using the OEM stock lines that came with the Akebono calipers.
Bill
Old Apr 12, 2013 | 10:30 AM
JaE35's Avatar
Moderator
G35 Sedan
You'll have no problems with 19's..
Trimming the dust shields is a piece of cake, scissors will even do the trick.
You will need universal stainless lines for the installation. If you need a link let me know.
Fluid doesn't matter all personal preference.
http://m.my350z.com/forum/showthread.php?t=432857
DIY in link
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
w4kj4k
Other Cars
Mar 6, 2016 08:06 PM
USAF_1013
Brakes
11
Feb 6, 2016 05:25 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
mushu
Jul 15, 2015 03:55 PM
