I have a 2007 G35 Sport RWD Sedan in 6MT and I'm looking to order a front right wheel bearing. Does anyone know what the part number is for a timken wheel bearing? I've searched online for hours and I can't figure out if its HA590376 or HA590027. I'm pretty sure the Infiniti part is 40202-EJ70A.
Thanks!
Thanks!
I need a right front bearing, too. If someone knows the Timken number and would post it up, that'd sure be great.
Thanks!
Thanks!
vqsmile
close
- Join DateOct 2010
- LocationSF bayarea (925)
iTrader Positive Feedback100
iTrader Feedback Score(1)
Liked:427 Times in 368 Posts
Quote:
Thanks!
Infiniti only sells the hub and bearing as an assembly. If the Timkin bearing is available for it, you can't get it from them.Originally Posted by theophilus
I have a 2007 G35 Sport RWD Sedan in 6MT and I'm looking to order a front right wheel bearing. Does anyone know what the part number is for a timken wheel bearing? I've searched online for hours and I can't figure out if its HA590376 or HA590027. I'm pretty sure the Infiniti part is 40202-EJ70A.Thanks!
I ordered part # HA590376
Will be attempting the install in t minus 10 minutes. Wish me luck!
I ordered part # HA590376Will be attempting the install in t minus 10 minutes. Wish me luck!
Good luck!
Although I predict you won't need it. Mine (after I got the right one) went in without a hitch.
The first hub I got wasn't the correct one for my car. I'm not sure if the sport suspension hub is different than the non-sport, but I had to buy the hub that matched the AWD part to get one that matched the original. The matching hub was a Timken HA590125.
How did it go?Originally Posted by theophilus
