Identify G35 Sport Calipers
Old Nov 25, 2013 | 11:41 AM
celwin's Avatar
I need assistance identifying the correct calipers for my G35 sport (07 model). I believe the ebay seller has his calipers labeled incorrectly. which of these two pics are sport calipers. I believe it's the 2nd one with 4 pistons?
Old Dec 6, 2013 | 12:04 AM
iloveG's Avatar
4 pistons total vs 4 pistons each. they fake aint no such thing spot calper for 07
Old Dec 6, 2013 | 01:23 AM
vqsmile's Avatar
First of all, are we only talking about front calipers here?
Is this supposed to be the front calipers from two different vehicles (one that is Sport, one that is non-Sport), or is this supposed to be a complete set from one vehicle (all four corners)?
Assuming you have the '07 G35 Sport Sedan, then the correct front caliper will be a floating type mono-piston caliper (like the first pic). There was NEVER any 4 piston Sport caliper on an '07 sedan. I'm 99% sure the same is true for the coupe too. Additionally, that second pic is a dual piston caliper, NOT a 4 piston caliper!
Not having had them myself (I have an '07 Sport), if that is a complete brake set (4 corners), then it looks like it may be a non-sport set, with the dual pistons being the fronts, and the mono pistons being the rears. However, if it is only the fronts from a Sport along with the fronts from a non-Sport, then the mono piston will be the Sport set, and the dual piston will be the non-Sport set.
This has been the source of much confusion in the past.
https://g35driver.com/forums/brakes/...ke-system.html
Old Dec 6, 2013 | 04:47 AM
Q8y_drifter's Avatar
Exactly what he said ^^
Old Dec 6, 2013 | 06:33 AM
celwin's Avatar
thanks. that clears it up
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
youngdip631
V36 Brakes, Suspension, Wheels & Tires
14
Jul 29, 2015 11:28 AM
laksjd84
Jul 24, 2015 05:12 PM
