Help?? 07 G35x wheels and suspension
Hey guys I was wondering if anyone could help me with lowering and putting new wheels and tires. There is a video of a v36 on vossen cv3's that I think I'm in love with. I don't know anything about camber, suspension and basically what has to be done to gain that kind of "look". Any help appreciated thanks
To get that look you would have to get coilovers and slam it, then you would go with a square setup which means same size wheels all around. So for the look you want you would need like 10.5s all around. You will then also need very low profile tires and probably need to stretch the tires for fitment. Keep in mind that your ride will become pretty stiff and you will bottom out on lots of things and you will have to learn to drive differently. After all that your camber will be out of wack and it will eat the tires up fast even after an alignment. Oh and since you have an X like me you won't be able to go very low since the transfer case will hit the ground. Just some things to think about. Hope this helps.
There's a couple X guys in this thread w/ aggressive squared setups, if you DIY the install it'll be a couple grand for the coilovers, camber set and alignment, + the cost of new wheels & tires
http://www.myg37.com/forums/brakes-s...post-here.html
Cajuncowboy
Jun 21, 2021 09:47 AM
kinetek
Aug 3, 2015 04:25 PM
