Will I screw up the differential by different size at front and rear tires on G35X?
Old Jul 11, 2019 | 01:52 AM
Stanley's Avatar
G35X
Hi, since G35X is AWD system, I was wondering if the differential will screw up by using 215/55R17 at the front tires and 225/55R17 at the rear tires?
The tire's thickness of 215/55R17 is 118.25 mm, and 123.75 mm for 225/55R17, there are 4.4% different between the two thickness.
The overall tire diameter will be 1.6% different between the two tires size.
Many thanks.
Old Jul 11, 2019 | 07:52 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You cannot run staggered diameter tires with AWD. Width is mostly unimportant but the diameter MUST be the same.
EDIT: Well technically you CAN but you need to disable the transfer case by pulling the fuse and thus it wouldn't exactly be AWD anymore...
Old Jul 12, 2019 | 01:12 PM
Stanley's Avatar
G35X
Thank you for your answer.
So will the AWD system get damage immediately by the tires setting? I already mounted the small size tires on the front, can I still drive it for just couple days that I commute for the work? (I already ordered the new tires for the rear which are the same size as the front tire, but I will receive it until next week.) Thanks.
Old Jul 12, 2019 | 03:23 PM
cleric670's Avatar
BANNED!!!
It will immediately start to sense a difference in wheel rotation and engage the transfer case, it would probably take a few weeks to overheat and destroy itself but you can eliminate that risk by disabling it's power.
Old Jul 13, 2019 | 01:33 PM
Stanley's Avatar
G35X
Gotcha! Thank you so much!
dEnbOy.GFM
Jul 3, 2010 09:07 AM
Gongo
Sep 1, 2006 04:09 PM
nickpro
Mar 8, 2006 07:38 PM
