DIY: Philips 6000k Ultinon Install
Old Sep 3, 2008 | 12:54 PM
  #121
blindS!de's Avatar
Originally Posted by Maxximtl
I just wanted to give my 2 cents about the 8k bulbs from 3bspec. Not only is there DRAMATICALLY less light, but my beam pattern is all screwed up. My clean cut-off is gone and I have ended up with "hot spots" of intensity instead of having an even dispersion of light. I don't think the tolerances on the chinese bulbs are the same as the Phillips. The bulbs are inferior from a construction perspective.
I'd recommend against buying these. I am going back to stock.
I use to have 6K's from 3Bspec, one bulb died after a week or so... contacted them and they sent me a replacement overnight... i requested for 5K bulbs instead and he sent it overnight.. no problems so far.. i do agree with less light and the screwed up beam pattern.. i experienced the same with my 6K's and when i did the switch to 5K's it was a lot better, although it's given 5K's will give you more light, i still think my 6K's were really defective.....
Old Sep 3, 2008 | 10:45 PM
  #122
SVLRx's Avatar
I have no problems with my 6000k's, but i do love the white color output that is has...
Old Sep 4, 2008 | 09:45 AM
  #123
Scooby24's Avatar
My beam pattern is fine and I don't notice any more hot spots than the stock bulbs.
Old Feb 5, 2009 | 08:06 PM
  #124
jbs1122's Avatar
I just installed some Phillips 6000 DS2's and im seeing the hot spots too. The beam pattern is not even and I have a bright spot on the drivers side and a pretty large hole of dim light on the passenger side. Is it possible that I just need some adjustments or do you think it is the bulbs that are messed up?
Old Feb 14, 2009 | 11:32 PM
  #125
jbs1122's Avatar
Installed the 3Bspec 8000ks and I'm much happier. The phillips 6000ks definately had a problem with the bulbs because all of the dark spots are gone and overall it looks like more output even though I went up to 8000's. Even though I have only had them a few days, I am very happy with the 3Bspec beam, price of bulbs, and shipping. Hope this helps anyone with the same problems
Old Feb 15, 2009 | 03:16 PM
  #126
G35Tiko's Avatar
i dont kno why i cant see th pics
Old Feb 15, 2009 | 04:08 PM
  #127
jsmonet's Avatar
just to add some fuel to this fire, my ultinons are still just fine, no hotspots, no problems. it's been almost a year--a month or two less than how long i've had the car
Old Feb 15, 2009 | 06:17 PM
  #128
KulG35's Avatar
where are the pics?
Old Feb 15, 2009 | 11:50 PM
  #129
jsmonet's Avatar
hah, i'll try to get a couple before it rains again
Old May 12, 2009 | 09:44 AM
  #130
eBayGEEK's Avatar
Where did the pics go =/
Old May 14, 2009 | 08:47 PM
  #131
popcornten's Avatar
+1 - there's no pictures!
and my bulbs are in the mail!
Old Jun 2, 2009 | 08:06 PM
  #132
nyckid's Avatar
where do you guys get your philips 6k ultinons from? whats a good place that carries em.
Old Jul 19, 2009 | 01:54 AM
  #133
kool_yaar's Avatar
^ Bump, just curious to see how the 3b Spec hids are doing reliability wise, i will be buying 6k within this week and was interested in seeing if these bulbs last a while to justify $60 or should i just spend ~160 on the Philips.
Thanks guys.
Old Oct 24, 2009 | 01:44 PM
  #134
OMG35S's Avatar
Bump For Some Pictures
Old Oct 24, 2009 | 02:06 PM
  #135
WILLIE BEANS's Avatar
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
