DIY: Wheel spacer vibration fix
Old Nov 29, 2009 | 07:47 PM
  #46
InTgr8r's Avatar
Staff ALUMNI (retired)
Just a straight piece of copper, then bend it by hand.
Copper is very soft.
Old Nov 29, 2009 | 08:27 PM
  #47
frshgcoupe's Avatar
Thanks, will try this tomorrow.
Old Dec 15, 2009 | 02:42 PM
  #48
Rottten Appples's Avatar
Originally Posted by intgr8r
& the moral of the moral of the story is......
Get aftermarket wheels with the right offset = no spacers
++++11111
Old Dec 17, 2009 | 05:16 PM
  #49
CooGAR's Avatar
Hey guys.....first post here. Just bought a pre-owned G37s M/T and have been doing a bit of mod research. One of the items I'd like to add to my car is the Ichiba 15mm or 20mm spacers. Some of the topics I have been reading on spacers have mentioned needing a camber kit to go with the spacers, namely H&R 20mm. A few questions...
1) Are the camber kits only required with H&R spacers AND if you lowered your car with H&R springs?
2) Any camber problems with Ichiba spacers??
Thanks!
Old Dec 23, 2009 | 10:11 AM
  #50
Roadtrip's Avatar
Wes_888,
You raise a valid point: When you move your wheels outboard, you will get more dust and debris flying off tire tread sort of lightly sandblasting sides of your car. This is why certain areas of some vehicles, especially those that flare out like in front of rear wheels, there is clear stone guard film placed, to protect paint. From corrosion stand point, you have to really watch fender wheel opening hem flanges for nicks and chips and touch them up when you find any.
I run 2005 17" 350Z wheels with winter tires on them in winter and the offset is 15mm more outboard in front and about 11mm more outboard in rear. I noticed a few chips on wheel opening hem flange in spring time. I watched for more to occur during summer months, when I run stock wheels, stock offset, but none did so it probably does have something to do with tire tread being more outboard.
I will say, my car looks pretty tough with the way the winter wheels are positioned out board, just about perfectly flush with fenders. It has me thinking about getting 15mm Eibach wheel spacers for stock rims. When I put stock rims on last spring, they looked a bit goofy due to how they are more inboard than my winter wheels. the only concern is adding wheel spacers introduces more variation in axial alignment of wheel centerline to hub centerline. There is no way around this. This is what causes wheel vibration with some spacers.
Old Oct 2, 2010 | 10:51 PM
  #51
mishmosh's Avatar
So lately, I've started getting vibration at 70-80mph. I thought with the copper wire in there, it couldn't be the spacer but I wanted to rule them out. I was thinking maybe one of my wheels was out of balance with the crappy roads here in Cleveland. Removed the spacers (man are the wheels tucked in!) and sure enough the vibration is gone. So I guess it might be a good idea to replace that copper wire with a new one every once in a while. But man, I wish these Ichiba V2's were trouble free.
update: new #10 copper wires-->smooth as a baby's bottom once again! I've probably done about 8 wheel changes before I replaced the wires.
Old Jul 15, 2011 | 08:10 PM
  #52
FIFE's Avatar
I am thrilled to report that the nasty shake I was experiencing between 68-78mph has been eliminated through the guidance of this DIY fix. Thanks to InTgr8r, cmo23, mishmosh, & wes888 for the advice! Such a good feeling to cruise through that speed range and not have the wheel & passenger seat tremble around.
Old Jul 15, 2011 | 08:17 PM
  #53
My Key's Avatar
Holy crap. This is exactly what I needed. Thank you for the bump!
Old Jul 30, 2011 | 12:49 PM
  #54
IIIHawKIII's Avatar
so i assume this still needs to be done?
Old Jul 31, 2011 | 12:50 PM
  #55
vqsmile's Avatar
If you get the two piece type, then most likely, YES.
But if you get this type, then most likely, NO:
Originally Posted by JOKER
how about hub centric spacers?
Old Apr 27, 2013 | 04:24 PM
  #56
supersonics1996's Avatar
I having this same issue on a 350z with 25mm Ichiba spacers. Any idead if this fix would also apply on the Z? How similar are that parts?
Old Apr 27, 2013 | 06:37 PM
  #57
mishmosh's Avatar
The part is the same for the Z so the fix will work.
jsimonk
Dec 22, 2023 03:49 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
