DIY: Clean your throttle bodies
Rating: Thread Rating: 2 votes, 4.50 average.
Old Aug 24, 2010 | 01:39 PM
  #136
Q8y_drifter's Avatar
Well, if you don't then TB cleaning is not really necessary, so the first dealer was really trying to screw you over doing something you don't need. As for the second dealer, if they said they don't recommend it then they're wrong as well.
I'd recommend doing it if you're having idle issues as a result of dirty TB's. Otherwise, it's not really worth cleaning them as part of any preventative maintenance or anything.
Old Aug 24, 2010 | 03:51 PM
  #137
Defratos's Avatar
You're Despicable
Man my car was idling really funny today while I was looking for a parking space.
It felt like it was going to switch off twice , I cleaned my TBs like 3-4 months back before installing the Stillen Filters. I need to take a look at them and see if they need cleaning. Might as well check the Airfilter at the same time to see if it needs cleaning too.
or maybe I just got crappy petrol this time around
Old Aug 25, 2010 | 10:13 AM
  #138
surma884's Avatar
Originally Posted by sm1074
I called a local Infinti dealership for my 30k service and they said that I would need a TB cleaning (runs around $150-170). I called another dealership who said that Infiniti or Nissan does not recommend TB cleaning. Who is correct?
If you are having idle or startup problems then you have to make sure the TB is clean. The person who said the TB doesn't need to be cleaned is wrong.
Old Aug 30, 2010 | 03:07 PM
  #139
changeover's Avatar
So I was planning on doing this but I have very little experience with anything like this. If I dont disconnect the electric thing, will I not have to do the relearn thing? I dont want to have to do anything except take some stuff apart, any further than that I will mess something up I know it haha.
Old Aug 30, 2010 | 04:21 PM
  #140
Just don't disconnect the harness and you'll be fine.
Old Aug 30, 2010 | 05:00 PM
  #141
changeover's Avatar
Thanks just did it, what a pain in the butt those screws are on the coupes. So badly placed haha. I burnt the fawk out of my hand when I put it on the engine cause it was the sun too. Oh well all clean now! Thanks for this thread!!
Old Aug 30, 2010 | 06:49 PM
  #142
Defratos's Avatar
You're Despicable
Yeah it helps doing it when the engine is cold
Old Aug 30, 2010 | 07:43 PM
  #143
changeover's Avatar
Engine was cold, just was a bit in the sun, didnt even think of that haha.
Old Sep 1, 2010 | 02:54 PM
  #144
jelloman's Avatar
even thought if I don't have idling problem, should I still try to open it and clean it? it has about 40k on it now and I am sure it has never been clean, will it be a good idea to do it just for prevention?
Old Sep 2, 2010 | 12:32 AM
  #145
FZ1's Avatar
FZ1
Just thought I'd add that cleaning only the part of the throttle bodies that contacts the butterfly valves with dry lint free cloths from Walmart has fixed the low idle issues I started having around 60k with the latest ECU update. Haven't done any re-learning yet either.
I followed a slightly different procedure that didn't require me to force the valves open by hand or disconnect the bodies from the plenum. Not as thorough a cleaning, but it felt safer and was still effective.
Described here http://forums.nicoclub.com/throttle-...g-t379999.html
Thanks a lot for this DIY, my dealer failed miserably at troubleshooting this.
Old Sep 2, 2010 | 01:21 AM
  #146
No problem. That's exactly why I did this myself. Dealer had no clue why it was idling the way it did and blamed it on my intake.
Old Sep 5, 2010 | 03:09 PM
  #147
TLTONEY's Avatar
Looked at mine today, 35000 miles, and they were nasty. Took me a little under 1 hour to clean both throttle bodies. The car started right up without any issues.
Thanks for the write up!!
Old Sep 28, 2010 | 10:28 AM
  #148
RemmyZero's Avatar
i always used to do this on my other cars, as well as cleaning the idle air control valve (which i don't know if the g has one). i followed this writeup last weekend, worked like a charm and my rough idle is gone. thanks Q8y!
Old Oct 1, 2010 | 09:17 AM
  #149
schwartzki's Avatar
Great write up...solved my idle dips, and she purrs now at idle and initial throttle tip in is much better as well thanks
Old Oct 16, 2010 | 09:18 PM
  #150
TomPeters's Avatar
Cleaned my throttle bodies today and everything went well. I just hit 50k miles this week so they were pretty dirty. I did not disconnect anything but am having some issues. The car idles great right at 800 rpms. The problem I have is that the throttle response is about 1 second behind. If I am going 30 mph in 3rd and let off the gas it takes 1 sec for the car to back off and jerks noticable hard. Another example would be reving up the car in neutral up to 3k rpms and then letting off the gas. The car will continue to idle at 3k rpms for 1 sec or two and then drop down to 1200 rpms for a sec before dropping back down and staying at 800 rpms..... weird. I went through all the step to reset the idle but I'm not having any luck. Not sure if this is what caused this but when I was cleaning the throttle bodies I pushed the butterflies open slightly to clean them. Could someone who has gone through the three steps of the idle air volume learning let me know what noise you're supposed to hear when doing step 2, throttle valve closed position? I didn't hear anything so maybe this is where I'm getting stuck. Thanks in adavance
You have already rated this thread Rating: Thread Rating: 2 votes, 4.50 average.
