DIY: Replacing your battery
Old Sep 15, 2012 | 11:21 PM
  #31
mathnerd88's Avatar
^ Or get a Kirkland Battery for like $65 that is far cheaper than comparable DieHard or Duralast Gold.
Old Nov 12, 2012 | 03:56 PM
  #32
RedBaronK's Avatar
Awesome DIY soundmike, I bought a Costco battery and did it today. Simple as hell... only bitch part was the weather stripping.
Which leads me to this question... can I screw up the installation of weather stripping and make the water leak into the car by any chance? Didn't exactly seem water tight to begin with...I put it together best as I could with some space between windshield and the strip.
Old Nov 12, 2012 | 05:27 PM
  #33
soundmike's Avatar
Welcome, glad it helped.
I doubt it either, that weatherstripping seems to be mostly to keep water away from the engine bay. Just be extra mindful of the part that covers the intake for the cabin filter and you should be golden.
Old Nov 12, 2012 | 06:26 PM
  #34
RedBaronK's Avatar
So that was the cabin air filter as I suspected... I always thought it was fresh air.. no idea it was engine bay air. Ew. Time for a new cabin filter.
Did u do the power steering DIY also? I think I saved like 300 bucks between these two... thanks bro
Old Nov 12, 2012 | 08:15 PM
  #35
soundmike's Avatar
Yep, the cabin intake is fed through the base of the windshield into the engine bay area. Definitely worth replacing frequently.
p.s. You're welcome on the Quick/Easy PS DIY. Always glad to help where possible.
Old Oct 19, 2013 | 10:51 AM
  #36
htj's Avatar
htj
Thanks for this DIY! After all these years, it's still valuable.
The dealership tested my battery last week when i was in for brakes and said it needed to be replaced...for $180.
I bought my own at advance auto parts w/ coupon, but they wouldn't install it b/c it's too complicated.
Used this DIY and did it myself no problem. Thanks for putting it together. It certainly wouldn't have been obvious without the steps posted.
Old Dec 3, 2013 | 03:20 PM
  #37
Steelers83186's Avatar
Used today, helped with all the plastic trim removal....Thanks!
Old Jan 23, 2014 | 08:54 PM
  #38
Travellin007's Avatar
Well, the frigid weather knocked my battery out and boy was I glad to come across this!
1. Made the job a snap, which was greatly appreciated in -20C weather.
2. Picked up the battery at Costco, I would have not thought of it. Saved money and I can attest to one poster's comments about no hassle return/warranty (had a flat, tire shredded, they replaced it).
For some reason, all presets are still there :-)
Thanks!!!!
Old Mar 15, 2014 | 09:32 PM
  #39
davrax's Avatar
Replacement Part Numbers
Can anyone tell me what the part number is for those plugs that are removed before the shroud comes off? I dropped one of mine and can't seem to find the part.
Old Jun 29, 2014 | 09:53 PM
  #40
vqsmile's Avatar
I'm glad it's helped y'all.
Yeah, can't have enough gold dust around here. Makes my car feel special that way. It's typically an even layer to look nice, but my hands can't keep... err... my hands off of 'em, which explains the hand marks.
How you manage to have the original battery cranking that long escapes me.
Well Mike, if you're still out there somewhere and you happen to see this, I just wanted to let you know that I F I N A L L Y had to break down and replace my original battery. It almost made it a full seven years (6y 10m) before it began to hiccup on me, so it certainly stands as testimony that it CAN be done. BTW, how's the Volt serving you Mike? I credit you with inspiring me to look at them and actually bought one for the mrs a few months ago. Hmm, come to think of it, it was just about the same time the battery died . . . maybe in some parasitic fashion the Volt sucked the final charge right out of the poor thing.
Old Jan 31, 2015 | 04:23 PM
  #41
Rider14's Avatar
G35x
So my '08 G35X, still on OEM battery as of January 31, 2015, failed a test during an oil change, so I'm off to buy a new battery. Likely will go Costco as well.
Glad to have found this thread - will change as soon as I have the battery.
Thanks for the DIY!
Also found out my rack and pinion steering is leaking...that's not likely to be a DIY job for me...
- Dan
Old Jul 10, 2016 | 06:00 PM
  #42
greg_atlanta's Avatar
2008 G35 Journey Sedan no sunroof
Thumbs up
+1 for Costco, been a member over a year but forget they carry stuff like this.
Got an Interstate battery at Costco for $85 with 42 month free replacement (but no prorating after that).. Autozone wanted $129 for their gold brand with 3 year free replacement and pro-rated to 5 years.
The Interstate book lists the 2008 G35 as a different size than the 2007, but I knew better and got the 2007 battery according to their book (size match and more cranking amps).
BTW... got my last battery at dealer after original failed at about 50% pro-rate, but since Nissan battery failed at 4 years 8 months would have paid 75% of cost (despite 84 month "warranty"). Glad I'm DIY this time.
Old Jul 10, 2016 | 06:10 PM
  #43
vqsmile's Avatar
Greg, I think what you meant to say was that you got an "Interstate" brand battery at Costco (instead of Enterprise).
Old Jul 10, 2016 | 07:01 PM
  #44
Wink
Ooops! Fixed.
Old Sep 18, 2021 | 07:19 PM
  #45
bfeldz's Avatar
Sedan
I am a bit confused
Have a 2007 Infiniti g35x Sedan.
I see most saying a size 35 battery. But then sometimes I see a size 24 battery. Do they both fit in the 2007 Sedan? Does it make a difference if it's a g35x or just plain g35?
I see that some people are saying they put the size 24 in and it worked, but just had to be reversed? And then others saying it must be the 35?
If it's possible and anyone can give me a more definitive and specific answer, regarding the battery and battery size for the 2007 Infiniti g35X SEDAN, it would be greatly appreciated.
I am trying to sell the car, so I was hoping to just get the cheapest possible battery to install JUST to sell the car. Unless installing a working battery is not even worth it if you are trying to sell it. But i figured people buying would want to turn the car on, meaning I would need a new battery.
Please, any help with this would be greatly appreciated. Thank you.
