New Stillen Dual intake for 07 350Z
Old May 24, 2007 | 04:55 PM
  #61
g u l8er's Avatar
^^^ yeah that sucks!
Old May 24, 2007 | 05:01 PM
  #62
UltimateGee27's Avatar
Originally Posted by viguera
The intake subject is one of the most disputed... mpg and power are inversely proportional. An intake cannot give you more hp and increase your mileage... it just doesn't make sense.
An intake that increases airflow will do just that... give you more air to the manifold. Without a subsequent increase in fuel to compensate, you're just running leaner and increasing mileage, but not hp. Doesn't make sense that you'll increase power by just adding air without reworking the AF ratio, and for that you need tuning. Then you'll have more power -- and reduced mileage since you're using more gas.
Old May 24, 2007 | 05:30 PM
  #63
trey.hutcheson's Avatar
Wow. 3hp. Not even a whole 3hp at peak. Nice.
If I owned an 07, I might actually buy it for the induction noise alone. I'm a big fan of the sound of the Stillen airbox on the first gen car. But anyone that purchases this kit for performance reasons is delusional.
Old May 24, 2007 | 05:32 PM
  #64
viguera's Avatar
I would buy it at $250... it IS two intakes after all, and it works out to $125 a piece.
But at $400 it's probably out of the "reasonable" price range for most people considering the "gains"
Old May 24, 2007 | 05:44 PM
  #65
IP05G35's Avatar
I don't see what the big debate is, intake tube setups don't gain you anymore horsepower really on a VQ35DE either, they are just for sound as well.
Old May 25, 2007 | 12:38 AM
  #66
logik05se's Avatar
its like i said....the sound is worth it to me. People mainly buy exhuast for sound as well so just think of it as a cheaper version. And personally to me the intake at WOT sounds better then an exhuast.
My injen cai is what gave my coupe its personality. that and my foot.
Old May 25, 2007 | 11:01 AM
  #67
chilibowl's Avatar
Aftermarket intakes sound best when the car is coming at you....the sound is almost disgusting...of how mean the car sounds
Old Jun 3, 2007 | 08:49 PM
  #68
John2.5RS's Avatar
That's one thing that I was surprised about... they're tiny. A cone setup HAS to be better, if you can keep the whole "airflow" thing going from the outside as it is now, it would be much, much better.
It's more important to have smoother airflow, and a panel filter has alot of surface area compaired to a cone filter. If a cone setup was better, they'd use it, panel filters actually flow quite well, and they don't seem to get as restricted as quickly as cone filters do.
Old Jun 3, 2007 | 09:29 PM
  #69
John2.5RS's Avatar
Exclamation
You can't simply compare MPG and power! MPG, engine load/ engine efficiency are more closely related.
Also, You can get more power and better milage, it's called increasing volumetric efficiency. by allowing to engine to flow more air through (make more "power" ) you also allowing it to do it's job better, which would increase your MPG, Due to the smaller load demands on the engine. For example; if it take 50 hp to keep it going 80 mph, and the engine only makes 100hp, that's 50% load, If you added an intake to the same engine, which gave you 20 more hp, you'd be looking at about 40% load going to same speed of 80, which would increase you efficiency and mileage.
I doubt your going to need a substantial increase in fueling needs simply from adding an intake, The factory ECU uses the Front O2 sensor to adjust fuel trims, it's not as good as a proper dyno tune, but I highly doubt that if your only doing an intake for the sound, your not going to waste money getting it tuned. you'd be better off saving money for a turbo kit, sounds a hell of a lot better than an intake.
Old Jun 5, 2007 | 08:38 AM
  #70
Just got an email from Stillen asking me if i want to pre-order the dual intake setup. They said they should be ready to ship the week of the 18th (June).
402838 - +STILLEN TWIN HI-FLOW COLD AIR INTAKE 2007 G35 SEDAN INFINITI
I am reaaaaaaalllyyy tempted to go ahead and put my order in and go ahead and order my Eibach pro-kit as well.
Ill give my self a week to hold out..
Old Jun 5, 2007 | 10:01 AM
  #71
Tiger's Avatar
est hp gains - 5-10
est hp gains w/ Stillen Sticker - 15-25
Did the email give any idea on the price of the Stillen Sticker option? I'd love to go with the "Dual Sticker" setup. I could deal with an extra 30~50 ponies!!
Old Jun 5, 2007 | 10:11 AM
  #72
da mayor's Avatar
I just want to hear the damn sound already--- get it moving viguera
Old Jun 5, 2007 | 11:08 AM
  #73
turboale's Avatar
One big motha...
Do the heat shields have an open side to them or do they use the oem "Ram Air" ducts? Just curious b/c if they are closed off I don't see how its going to give any huge change in sound...
Having just plugged all my silencers on the intake it changed very little. The main reason intakes are so loud is b/c they remove the airbox. If the heat shielding is closed off from the engine bay I don't see how it would be any different than a full air box...? am I missing something here?
Old Jun 5, 2007 | 11:36 AM
  #74
i have yet to see a picture of the set up so i have no idea how the boxes will go..i hope they are just an arm with filters
Old Jun 5, 2007 | 11:44 AM
  #75
**EDIT** Sorry guys the price i put up earlier was a Jobber price for wholesalers. Retail is as follows:
$399.00 + shipping
not bad for 2 intakes $200.00 each
Seeing as tho i have been buying Stillen products for a very long time , I am very satisfied always with the end product and performance i get. I highly doubt anybody can dispute that.
