Intake Silencer Bypass Writeup!
Old Jun 14, 2007 | 12:48 PM
viguera's Avatar
Originally Posted by turboale
Sorry guys, I have been out of town for the last week... I'll do what I can to get a sound clip. Its not THAT noticeable, just deeper. I'm working on something to get some more out of it... if anyone has any ideas feel free to chime in. I want to do something like a deckplate which would be able to be able to switch from open element to closed air box in a matter of seconds. I'll post pics of the setup I have on my 4Runner which is what I'm shooting for, but its not going to be easy... Its also suppose to rain for the next week and a half so the G will be in the garage for most, if not all of it. I'll let you know if I think of anything!
Food for thought...
Thanks GC! I also updated my mistakes in wording. Thanks!
You can always try to retrofit one of those exhaust cutouts and see... not sure where you're going with it though...
Old Jun 14, 2007 | 12:52 PM
Altersys's Avatar
what you've done is removed a helmholtz resonator. tytpically they are used to introduce inverse-phase resonances to cancel primary resonances, hence making the intake "quiet". a possible second use is to eliminate power-robbing resonances that the engine is not tuned for.
i'm not saying anything definitive, but it is *possible* that this modification on its own may reduce your output at certain RPMs and loads.
Old Jun 14, 2007 | 05:44 PM
Tiger's Avatar
This is true, however, it can't be any worse than taking the whole thing out and bolting on a cone filter.
Old Jun 14, 2007 | 05:53 PM
Altersys's Avatar
which is why i also won't do that
but yeah, if you're gonna lose HP for noise, do it for free (nearly)!
Old Jun 14, 2007 | 08:49 PM
Goodstuff's Avatar
Well I just did this, but I took a different route.
What I did was unhook the air boxes and lift them up. Once I could see the resonators. Then instead of taking them out, I took electrical tape and cut 8 slices. I placed them over the whole 8 times in opposite directions and then took a long piece and went around them to secure them. Then I fitted the air boxes back on. Same thing as taking them off, just less hassle.
Then I took off the engine cover. I figure it only traps heat, and while doing so I figured there would be no difference, but I **** you not the car does feel a tad different. Kinda like a turbo car gets heat soaked, it always feels like its 70 outside. Maybe its in my head though lol.
I also noticed something, when you take the cover off you realize that there are other ballast along the intake tube. And there is a tube that goes from one intake to another. All of this should really be simplified so that maximum smoothness is achieved.
Old Jun 29, 2007 | 08:29 AM
Tiger's Avatar
Any sound clips on this setup yet? I'd be interested to hear if this sounds much different from the Stillen and Fujita intakes that are out now.
Old Jun 29, 2007 | 01:53 PM
hyukki's Avatar
Wait, doesn't the air travel through the silencer into the filter box?
If I understood you correctly, you just blocked off the air supply to the engine... pics would definitely help...
Old Jun 30, 2007 | 10:23 AM
Tiger's Avatar
The silencers are not part of the normal flow of air. They are extensions off of the air box, and intake tubing. He did not cut off any air flow.
Old Jul 1, 2007 | 11:23 AM
Cyanide Ride's Avatar
There is a little more growl at low RPM, but nothing to run to and tell your mother about.
I removed the silencers and instead of gluing the holes, I taped them off.
It's something to do if you have about an hour or two to do.
Old Jul 1, 2007 | 01:27 PM
Altersys's Avatar
as i said, they are helmholtz resonators... while they may not be a main path of flow, they do affect the way the pressure waves enter the intake tract. their primary purpose is to normalize flow characteristics throughout the rev band.
Old Oct 16, 2007 | 04:54 PM
CoppellStereo's Avatar
will taking these off have any effect with the stock intake?
Old May 5, 2009 | 05:09 PM
smr514's Avatar
wow this job seems so complicated!! or is it just me?
Old May 5, 2009 | 07:14 PM
Csquared's Avatar
it's not i just tapped up the hole with electric tape
Old May 5, 2009 | 07:17 PM
blindS!de's Avatar
the silencer hole?
Old May 5, 2009 | 07:59 PM
  #30
johnnyzee's Avatar
hey csquared, you really notice a difference in sound?
is this worth the effort?
