Okay... so I'm hearing weird engine noises.
Old Jul 17, 2007 | 01:17 PM
JdM_G35's Avatar
add a little bit more oil and see if it goes away, our dip stick tends to to trick us often
sounds like the valves are grinding, from not enough oil.
Old Jul 17, 2007 | 01:22 PM
Altersys's Avatar
Originally Posted by cnugs127
The noises seem to be random and not just when cold.
I could have driven 50 miles then start to hear the noise. After maybe 5-10 minutes it goes away. Sometimes it doesn't.
again, what type of oil do you use (brand/weight) and how often do you change it? also, what is the ambient temperature range?
Old Jul 18, 2007 | 01:58 AM
cnugs127's Avatar
I bring it to my friends shop and he does the oil change for me. They use whatever weight the owners manual calls for (I forget).
I live in the SF Bay Area, so it's normally between mid 50's to mid 70's.
Old Jul 18, 2007 | 02:07 AM
Altersys's Avatar
i would be very curious to know what brand and weight you are running.
if you aren't already, try a synth oil at your next change and see if the sound goes away (when the engine is hot). i use amsoil 5w-30 ("asl") and also live in the sf bay area. only get ticking on cold startups and it goes away pretty fast, as i said.
Old Jul 18, 2007 | 10:12 AM
cnugs127's Avatar
I just changed my oil. Might as well change it again with syn and see what happens. Thanks.
Old Jul 20, 2007 | 07:21 PM
G35S's Avatar
cnugs, those are your hydraulic lifters. it's probably noisiest when the engine is cold and the oil has not pressurized them.
i've found that nissans always have noisy lifters.
and it's perfectly normal...
+1 Altersys.
This is my 3rd Nissan. We have two in the garage now and the fuel injector tick is just a characteristic of their engines.
Don't worry cnugs, but you might run it by the dealer to set your mind at ease...
Old Jul 20, 2007 | 07:23 PM
Altersys's Avatar
hmmm, i said hydraulic lifters, not fuel injectors.
those make noise too, but they're quieter than the lifters and are usually drowned out by all the other engine noises. you usually only hear those when you're testing them with the engine off.
Old Jul 22, 2007 | 08:37 AM
G35S's Avatar
Ooops. Based on several previous discussions about the fuel injectors I misread your post.
But the sound I am referring to has been present with all 4 Nissans I have owned:
'97 Hardbody pickup
2004 Titan
2004 XTerra
2007 G35
It comes and goes. You'll hear it and then the next moment it will be gone. When I am driving the engine purrs like a kitten.
No informed opinion from me on the hydraulic lifter sound.
Old Sep 18, 2007 | 11:25 PM
silverG2007's Avatar
Ticking at idle and ticking a full throttle are two completely different issues.
It sounds like this guy has the same problem I have, ticking at high rpms under full throttle.
It's not an exhaust leak or anything like that for me because..... 1. It doesn't happen all the time, only about 50% of the time. and 2. It's not load based, for me it's rpm based.
I can cruise at 6k in 1st gear with no load (using manual mode) and I get the same tick as WOT in any gear.
Old Sep 19, 2007 | 12:04 AM
///M32G35's Avatar
I have no ticking, but I do have a sort of tinny, almost raspy sound, somewhat reminiscent of my M3, at WOT. Is this what you're describing OP? Seems normal for a high strung engine like this.
Old Sep 19, 2007 | 09:41 AM
Altersys's Avatar
+1 i've noticed that too. i think it's an artifact of the intake system. it does sound kinda funny at WOT. first time i heard it i was surprised.
Old Sep 19, 2007 | 01:39 PM
I have the regular engine sounds too.
But the loud ticking is definitely NOT normal sounds. And like I've said before, it only happens 1/2 the time. "Normal" sounds happen all the time and are consistent.
When I floor it.... 3k, 4k, 5k, normal revving sounds....... 6k plus..... A wierd loud ticking (twice as loud as regular engine sounds) kicks in until redline.
The service manager that heard the sounds agreed they aren't normal.
Old Sep 20, 2007 | 12:49 AM
hyukki's Avatar
I think everything is fine. The sound is gone, I just hear it more often after oil changes. I think you are describing my "problem."
It was definitely not a tick, that's for sure.
Old Nov 13, 2008 | 09:21 PM
greg_atlanta's Avatar
2008 G35 Journey Sedan no sunroof
I have the same noise on 08 sedan with 2500 miles (still on factory fill oil) and sometimes it sounds "normal" and other times it sounds like something is loose in the drivetrain. Are there shields on the exhaust to protect the cats? My '92 Q had those and removing them fixed the buzzing/rattling noise.
Old Nov 13, 2008 | 10:30 PM
  #30
ParkStr8's Avatar
I have the same noise. As far as i can tell it's the Nissan lifters as others have stated. I was next to a newer 350Z with our engine and it had the same sound as ours...
The raspy sound i hear on acceleration is from the exhaust when it's cold.
Just my .02
