Is the Intake worth it?
I just installed the Fujita intakes. I must say, it felt a little different, but it was hard to tell. Definately love how it sounds, not to mentio when I pop the hood to show people. Looks sick I agree!
My technician told me "Do not install them".
He told me the original intake sucks the air from the grille.
But the modified intake will suck the air from the engine room.
The air in the engine is much more hotter than the air from the grille.
It's no good for the engine.
I am not sure is it correct or not about what he said.
Can anybody give me a hint? Thanks.
Originally Posted by UltimateGee27
i think this is the exact reason Stillen engineered their intake with the box around it. The box makes sure that the air coming into the intake filter is as far from the block as possible and receives air from underneath and from the front. The rear and sides are blocked off. Much like the factory style i believe
At the end of the day who the hell cares, i love the sound of it...and honestly the car isnt that fast regardless...intake or not.
^^ I don't necessarily believe that. When an engine is hot the engine bay is hot. Yes when driving you will get a little circulation but it is still hot engine bay air. The stillen intake looks like the best bet with the heat sheilds and near stock placement, plus it has the rubber intake tubes rather than the metal fujitsu ones that inevitably will have heat soak. Even though the air is moving fast through the tube it still heats up. On the bright side they have a "bling" appeal
Personally I will not be putting one on my car to keep engine noise at a minimum. Like said before this car really isnt that fast, it is not slow with a 13.9 1/4 stock but I'll use my sports car to go fast, not my luxury car.
fujita states that if you are moving(driving) you will always get fresh air...you only really get hot air if you are at idle for long period than the engine bay gets very hot...but hey i just love the sound!!!!
really? wow i wonder how they figured that out...they must have a specialized team of rocket scientist over there at FUJITA
Originally Posted by logik05se
and a mechanic told me (quite a few actually) that fresh air is rushing so fast under the hood, that i should not worry about sucking in hot air from the engine. They said the only time I would have to worry is if i leave the car idling for about 10 minutes in place on a hot day and then drive off. I will then notice a difference for about 10 seconds until that engine air is filtered out.
well I mean this argument is pointless because it's easily settled: compare dyno numbers for cars with stillen vs. fujita, if you want include those with exhaust.. as far as I know, numbers are close, very similar anyway, so this shows that the 'extra hot air' isnt having much of an effect..
I personally like the way the fujitas look better, and they're a bit cheaper so.. i'm still leaning towards fujita..
It's kinda like, I have the 18" wheels and you have the 17" wheels. They all turn in the same direction. Some look better, cost more, or less, and basically are subjected to the same crap. Ergo, I have the Fujita intakes, whereas you (general) might have the Stillen. Mine looks way better, might get a little hotter, and yours looks like, well, not like mine, and sounds a little different. However, I'm sure they both make roughly the same power, if any. It's basically all pointless ranting and complaining. I mean really, when Vortech or Stillen comes out with their superchargers, we'll be doing the same damn thing. Can't wait!
