Berk HFC installtion???
Old May 11, 2008 | 07:27 PM
Lucky_One's Avatar
has anyone on this forum installed Berk HFC on their 07 sedan? i read almost everything in the g37 forum and have a pretty good idea about what i should do. when i took a look under the car, it seems like it is possible to get the top bolts from under the car, has anyone tried? g37 forum says to remove the top bolts from top of the engine, which will be a hassle. any tips? and i know taking it to a performance shop would be better....but i kinda dont trust anyone with my car other than me. i would be less angry if i mess something up than if someone else did it.
Old Jun 29, 2008 | 08:04 AM
earth0's Avatar
Did you installed Berk HFC. Any result? How you installed it BTW? thx!!!
Old Jun 29, 2008 | 08:23 AM
Og_Dave's Avatar
i installed some Test Pipes for my g35, and it shouldnt be any different , theres 3 bolts , 2 of them you can get underneath the last 1 i went from in the engine bay with an extender and had my buddy give me a hand and got it off easy.
took no more then an hour for both. but remember to spray some wd-40 or some penetration spray on the bolts for a good 30mins to loosen it alittle, be much easier haha hope that helps and goodluck with the install
Old Jun 29, 2008 | 08:31 AM
earth0's Avatar
Thx! BTW will HFC from Berk pass EMission Test..What i meant was Yearly Inspection since Berk Tech Confirmed on their website about
OBDII & 49 state compliant I live in NYC. Thx again if you can advice.
Old Jun 29, 2008 | 09:57 AM
Lucky_One's Avatar
i tried twice to install it, and failed. so finally had a tech do it. cost about 150, for about hour and a half. i think if u have an impact wrench, several long extensions, wd40, car lift, time, and some friends, i think u might be able to do it if u know anything about bolt on mods. the tech basically did what i planned to do, but i didnt have an impact wrench. good luck with yours.
Old Jun 29, 2008 | 10:12 AM
earth0's Avatar
Do you have any vdo sound clip? I really wanna hear it.THX BTW
Old Jun 29, 2008 | 11:42 AM
Lucky_One's Avatar
actually i have off from work today, and was planning to make a video of the exhaust. ill try to post later today.
Old Jun 29, 2008 | 11:47 AM
earth0's Avatar
Thx! Can't wait to see that. I will have mine install with all stock. Just took off Stillen Short Intake.I dunno i feel like more power w/stock one.
I will post mine when it's done one thing at a time.
Old Jun 30, 2008 | 11:22 AM
Lucky_One's Avatar
https://g35driver.com/forums/media-share-v36-sedan/230220-berk-hfc-installed-video.html
the video.
Old Jul 5, 2008 | 09:58 PM
Og_Dave's Avatar
I'm not positive if the berks will pass, but if they said it does then it should.
And 150$ to get them installled? Damn too much.
All I had was jack stands , 2 ton lift and 3 extentions to get the job done, It ook time but if you don't mind some elbow grease here and there it won't take long, and atleast you will gain some experience right
seagrasser
May 3, 2022 09:43 AM
magnetism80
Jan 27, 2016 12:57 PM
DRG35R
Sep 16, 2015 05:33 AM
CoupeObsession
Aug 17, 2015 01:05 PM
