Crank/Underdrive pulley
Old Dec 25, 2008 | 04:57 PM
G35Robby's Avatar
Originally Posted by 1SlowG35Sedan
Haha you can say that again. He was post whoring on Socalg till 5 am yesterday!
Thats cuz im the fvcking **** lmao
and a post ***** lol
i got more posts on socalG than driver and i joined socalg in november haha
Old Apr 1, 2010 | 03:24 PM
hrp783's Avatar
bump, any updates on the underdrive crank pulley?
I had a civic and had the AEM alternator and crank pulley, it def made a difference, pulled hard and rev'd up faster, especially when vtec kicked in
on the civic it was probably the best bang for the buck mod to increase power.
i talked to Stillen, they said it produces 10hp at the wheels, no dyno sheet avail.
but will reduce other acc. (steering, alternator...) by 20%, i have a big system (JLw7 & 1000 watt amp) kinda makes me worry about alternator strain, i guess i need to get some type of cap for the sub.
the guys that have the underdrive pulley, what do ya'll think about it?
Old Apr 1, 2010 | 03:32 PM
hrp783's Avatar
Unorthodox Racing makes stock diameter pulleys as well.
check out this page, looks like they have a dyno sheet
http://www.unorthodoxracing.com/Item...ke=20&Model=66
Old Apr 1, 2010 | 05:41 PM
kool_yaar's Avatar
^ i would search for and read subys thread first where he had his engine replaced due to the AF pulley, i know it does not happen to every car and is a rare occurrence as many have had their pulleys for years with no issues, but its best to see both sides of the picture before making your decision.
I am not going this route because, the possible downsides outweigh the possible gains from the pulley IMO.
Old Apr 1, 2010 | 10:24 PM
hrp783's Avatar
Good point, thanks yaar
Old Apr 1, 2010 | 10:25 PM
hrp783's Avatar
ek dam number von! yaar!
Old Apr 7, 2010 | 11:10 AM
firozu's Avatar
i have the pully but havent installed it..i am planning on a system as well what do u guys think?
Old Apr 7, 2010 | 11:40 AM
suby01's Avatar
pulleys with after market system are definitely not recommended. just google search any website and it will tell you the same.
Old Apr 12, 2010 | 12:26 PM
firozu's Avatar
so which would u guys suggest pulley or system???
Old Apr 12, 2010 | 02:23 PM
LakeShore_Slate's Avatar
The radiator is the prob. the biggest problem about 45 min install. I had a well respect mechanic look at it.
Old Apr 12, 2010 | 02:33 PM
suby01's Avatar
well depends on what your looking for. pulley is a performance mod. however does not give horsepower gains. and noone besides you will know you have it. and system is a completly different mod, where people who notice it and it will make your car stand out but also make your car slower because of the weight.
so what are you looking for fast and quiet or slow and loud.
Old Apr 13, 2010 | 09:37 PM
firozu's Avatar
so what would b the repercussions of having both?? liek if i put 2 subs... and the pulley?
Old Apr 15, 2010 | 12:40 PM
suby01's Avatar
wikipedia quote for you....
""""Usage Concerns
Be careful if your car is driven on the street to not have more than 15-20% underdrive. Some companies also offer stock diameter crankshaft and accessory pulleys. Poorly designed cheap pulleys or copies and knock-offs of major brands can have severe side effects because of too much underdrive of the alternator, power steering, and/or air conditioning units, which are not spinning fast enough. These lead to dips in alternator voltage, power assist, and air conditioning effectiveness may be noticeable, especially at idle. The headlights may dim when coming to a stop, or the stereo may lower in volume, for instance. Too much underdrive for a race car, this is not of concern, but for a daily driven vehicle it can be a major annoyance.
Changing the original crankshaft pulley can have negative effects if the replacement pulley is not manufactured properly. A crankshaft or accessory pulley that is not machined or balanced properly can cause severe damage. For most domestic V8s a harmonic damper is necessary to absorb crankshaft vibrations. Early to mid-year V8's kept the pulley and damper as separate components. Most late model V8s now integrate the damper and the pulley into one part. For small displacement engines found in many import and domestic vehicles (4.0L and under) the original crankshaft pulley only serves to quiet noise vibration and harshness (NVH) you hear in the occupant compartment. Although it may look like a damper on V8's engines it serves no protection function to the engine. It is the same as the baffles and resonators found in the intakes and exhausts systems of most cars today that serve to make the engine as quiet as feasibly possible. The first things most enthusiasts do is install high flow intakes and exhausts; the quieting function is eliminated."""
simple terms will strain your alternator, and in my case may cause crankshaft damage causing engine failure. good luck.
Old Apr 15, 2010 | 02:40 PM
firozu's Avatar
""""Usage Concerns
yea i read that not too long ago....i guess ill hold on to the pulley till i get more feedback on it...if anyone has it installed how is it affecting ur accessories currently? like is ur a/c slower and what not? Because I live in florida and without a/c the car is worthless
Old Apr 15, 2010 | 07:57 PM
  #30
implicitv36's Avatar
first off a couple pics.. as you can see compared to the mag this thing is huge, weight difference is stock is a little over 8 lbs and this one is 2 lbs so im losing 6lbs off of the turning ratio.
and now the quick review...didnt do the dyno after the install because per UR that results will show after 5-7 days or 200miles where maximum hp will be gained.
IT WAS A BISHH AND A HALF TO INSTALL nut was on so hard on, it says only 30 ft of tq thats less than a wheel nut. that was not the case. took like 2 hours and three broken tools until it was loose.
it was snowy out and still icy so i never got on it until i put about 50 miles on the car and just now coming home highway ramp was all salted and dried out. stopped vdc off shifted first. slip light hasnt been blinking this bad since idn. almost went sideways.
second pulled and third was like with boost. i dont know i still need clean stretchway and for it to breakin but so far. super power gains.
Hey move the pulley its in the way
