Decided - My exhaust project.
Old Jun 30, 2008 | 03:24 PM
sredish's Avatar
Going to try and save a little cash and see if I can make a nice exhaust for the car.
From the cat pipe back, I'll coue out with 2 1/4" tubing into a Magnaflow 14385 dual in/dual out muffler that has X-pipe internals, polished to go in place of the resonator. From there, follow back to the stock muffler positions with 2 1/4" tubing into 2 Magnaflow 14829 mufflers. These mufflers are pictured below. I got all three for just at $400 and talked to my shop and we'll be putting it all in for roughly $150.
I was thinking about stepping up after the dual in/out res to 2.5" and then 2.5" back but was afraid the step would be a potential drone point. My other concern is the mufflers with tips already attached; I hope 1) the tips are are long enough to reach where they should and 2) the fact there's not a lot of space between the tip and the muffler isn't a problem. I want to do High Flow Cats but am going to wait and see how this sounds before I make it any louder. We shall see.
Got them from PlanetMaganflow.com with free shipping.
Magnaflow 14385
Magnaflow 14829
Any thoughts or opinions, I'm all ears.
Old Jun 30, 2008 | 03:27 PM
jdmgee35's Avatar
Just save up a little bit more and get a real one that has the R&D behind it. IMO.
Old Jun 30, 2008 | 03:30 PM
sredish's Avatar
that'll be part of the fun, won't it?
Old Jun 30, 2008 | 03:56 PM
terrycs's Avatar
Sounds like you have a good starting point ... I had all those components on my car the first time around. It was a little loud for my taste but but not at all loud to many of the younger guys that have heard it.
There are some comparison clips here:
https://g35driver.com/forums/showpos...5&postcount=72
Old Jun 30, 2008 | 04:07 PM
sredish's Avatar
thanks man, if you weren't able to notice, i stole some of the design cues off your original system. i've listened and studied your youtube vids. if it comes out anywhere near the sound of your car, then I'll be pleased; although I am hoping it won't be all that loud. if it is, then I'll have to make some small changes.... but I'll get it.
Old Jun 30, 2008 | 11:09 PM
silverG2007's Avatar
What do you mean?
The real R&D comes with the mufflers. And Magnaflow has a great history with mufflers.
There's no "magic" to the piping. Minimal bends and the right size piping.
Old Jul 1, 2008 | 12:54 AM
jdmgee35's Avatar
Originally Posted by silverG2007
What do you mean?
Then how do you explain the different HP #'s with different exhausts?
Old Jul 1, 2008 | 10:28 AM
sredish's Avatar
the hp differences between most of these systems is single digit numbers and the same system from one dyno to the next can vary that much so you can't take one system's dyno for gospel as to what it will do on your car at your local dyno. most good systems are going to be very comparable and by good, I mean a quality h or x with true dual setup.
unless someone's willing to buy/take 3 or 4 of the top systems and do a same day back to back to back comparison to prove otherwise, then I'm not going to spend 3 or 4 times more than necessary. this isn't my first time doing exhaust work, I have of experience with these types of projects and I'm more than confident that i/we can build a system that perfroms just as good. sound is the main concern and can easily be tuned out. the FI prototype used pretty much the same mufflers so sound should be comparable to that.
Old Jul 1, 2008 | 01:40 PM
Marketing BS.
You don't actually BELIEVE the numbers that manufacturers claim for aftermarket parts, do you?
If you do, I added up the claims for HP gains for bolt on parts only for my last car (02 Trans Am). According to the claims, I could have about a 500hp bolt on only car! (160hp over stock).
Reality was closer to 50hp over stock with all bolt ons.
There's only so much power you can "uncork" with bolt ons. Start with an open intake, and open headers...... then subtract as you add piping, filters, mufflers, etc.
Old Jul 1, 2008 | 03:13 PM
blindS!de's Avatar
Magnaflow 14385
Magnaflow 14829
The 14829 will not fit because of the way the hangers were setup on our cars, im actually in the process of swapping my 14829's for some 12225's and getting me some 35121 tips.. the inlet on the mufflers your suppose to get has to be on the side not centered
Old Jul 1, 2008 | 03:39 PM
sredish's Avatar
So you mounted the 14829 and had problems or it never even got under there?
I did notice and was aware of this but figured it wouldn't be too hard to make it work. Guess we'll see, I could be wrong.
Old Jul 1, 2008 | 03:46 PM
blindS!de's Avatar
Nope never even got mounted, there was no way it could be done well that is unless you wanna hear rattles underneath then there is a way to do it..
I'll take a picture of what im trying to tell you if you want
Old Jul 1, 2008 | 03:55 PM
sredish's Avatar
hmmm, i'll check it out and look at that part number your mentioning.
Old Jul 1, 2008 | 04:08 PM
blindS!de's Avatar
Check out these threads they all had used 12225 as the muffler.. i wanted to try something different as well that's why i bought the 14829 at first seeing that it already comes with tips plus i dont have to paint it... but failed lol
https://g35driver.com/forums/g35-sedan-v36-2007-08/225857-magnaflow-first-day-vids.html
https://g35driver.com/forums/v36-engine-exhaust-drivetrain-fi/199250-installed-custom-magnaflow-exhaust-today-pic-video.html
https://g35driver.com/forums/v36-engine-exhaust-drivetrain-fi/195791-custom-magnaflow-exhaust-pics-videos.html
https://g35driver.com/forums/v36-engine-exhaust-drivetrain-fi/188444-just-finished-my-customer-sleeper-magnaflow-performance-exhaust-custom-system.html
hope that helps GL
Old Jul 1, 2008 | 05:02 PM
G35power's Avatar
Yes that what i have on my car 12225
