please help, i am stuck!! power wire from engine to trunk
Old Sep 22, 2008 | 02:22 AM
g35nerd's Avatar
I am installing a sub into my new 08 g35 sedan. I removed the battery, and found two metal tubes going through a rubber grommet. I have been told to just stick the power wire through and i should appear behind teh glove box. But its not there!!
it is showing behind the wheel well. I removed the rubber panel behind my front passenger tire, and its there. i dont see any holes that leads to the glove box.
is the wire supposed to appear under the carpet, behind the glove box?
What am i doing wrong!!
ps. i have used the search.
thx in advance
Old Sep 22, 2008 | 03:15 AM
Christopher____'s Avatar
use coat hanger to fish the wire thru.
Old Sep 22, 2008 | 02:15 PM
silverG2007's Avatar
I went through a hole below the glovebox not into the glovebox.
Old Sep 22, 2008 | 03:00 PM
kool_yaar's Avatar
you should take out the glovebox and its holder if you're having problems that we you can work on it much easily
Old Sep 23, 2008 | 12:31 AM
g35nerd's Avatar
I am supposed to remove the glove box??!?!?!
what do you mean it drops below the glove box? does it come from under the carpet?
do i need to punch a hole through the gray carpet lining?
btw, thx for the answers.
Old Sep 24, 2008 | 02:24 AM
g35nerd's Avatar
anyone? I spent a couple hours just on getting the wire though. Im not a pro, but im no noob either. This is my 5th system install.
Old Sep 24, 2008 | 09:43 AM
Boston's Avatar
I'm speaking as a coupe owner but I dropped the glove compartment, fed my power lead from the battery compartment through the rubber grommet and down to the ECU area. I pulled the passenger door kick trim that secures the carpet and ran the wire under the carpetalong the door and then under the back seat to the trunk to cennect to the amp. I would assume on the sedan, you would pull the trim on both the front and rear passenger door to accomplish the same thing.
Old Sep 24, 2008 | 10:04 AM
kool_yaar's Avatar
Its the same as the sedan, as i said you should take off the glove box and the holder and it will make your life much easier, just pop off the glove box from the lower joints and then i think there are like 7 screws, take them off and that will expose the firewall where you SHOULD see the wire if you have fed it correctly through the gromet
Old Sep 24, 2008 | 12:45 PM
g35nerd's Avatar
Thanks all , i will try it out today.
Old Sep 24, 2008 | 05:55 PM
d280c's Avatar
I fed my power wire thru the rubber gromet on left side by the brake fluid, did not have to remove battery
Old Sep 24, 2008 | 06:09 PM
kool_yaar's Avatar
thats actually also another place to pass the wire and would be easier but the only reason i did not do that was beacuse i did not want the power cable to be visible in the engine bay for nmy dealer to see as he's _____.(u can fill the blanks) anyways either way is fine.
Old Sep 24, 2008 | 06:47 PM
g35nerd's Avatar
yup, i passed the power wire through the rubber groment on the left side of the battery. this is alot easier than i previously thought. I hope i wont have any issues returning the car in 3 years.
Old Sep 24, 2008 | 06:55 PM
mishmosh's Avatar
Do you just get speaker level sub input from the rear sub?
Old Sep 24, 2008 | 07:34 PM
kool_yaar's Avatar
I tapped from before the BOSE with a LOC(line out converter)
Old Sep 24, 2008 | 08:05 PM
g35nerd's Avatar
hey kool_yaar,
which wires did u tap before the bose amp? I also have a LOC. I just need the wire colors and i am set!!! how about the remote turn on wire, which color is that?
