Driver sport mode stuck - won't shift up or down
Old May 17, 2009 | 08:01 PM
stevej88's Avatar
I bought the car in march of 08 installed the paddles in June, the problem happened for the first time in December of 08. Had everything rectified in march of 09.
Here is a picture of the old shifter unit "The one that went bad" that the dealer gave me back.
The top is the long silver pole with the white shifter button at the top. The angled metal piece at the bottom connects to the transmission unit. There is a white box on the shifter unit that the dealer said burnt-out, this is where my problem happened at.
I had the same problem you had (RowanBuds) but later it was the opposite. If I used it in DS mode it would stick there but then it later stuck in D mode. You are totally correct when you say if you powered the car on and then off real quick it would still happen but after a period of time it would not happen again. . . . . To me this sounds like a short or a faulty part going bad. Plain and simple I think there is a design flaw with the unit. Needless to say since I installed the paddles myself and this happened I got charged for a new unit. In your case it would be an issue though. I have had several people PM me and tell me this happened to them too and they didn't have the paddles and or had the paddles as a stock option. In the notes from the Infiniti dealer it said replaced driver shifter unit. Customer states that shifter will not go into DS mode intermittently.
Like I said in the previous posts it got worse over time and eventually it would fail after a couple minutes of shifting up and down. I have not installed the paddles since then but plan on having the dealer install them when I go in for my next service. According to them everything is back to stock now and if the problem happens again they will warranty it as if it were their problem.
Good luck and post up what happens or what they replace when you take it in.
Thanks!
Attached Thumbnails Driver sport mode stuck - won't shift up or down-shifterunit.jpg
Old Mar 14, 2010 | 03:37 AM
voltagefx's Avatar
Did they happen to give you the part number for that piece/switch that went bad? I figure it could be beneficial to those of us without a warranty (over 60k mi) who will be replacing it ourselves if it should fail...
Thanks.
Old May 15, 2011 | 07:47 PM
G3065's Avatar
Hi everyone,
It's been a while since anyone has posted anything about this but last night I had the same issue and I eventually had to park the car and leave. Once I came back the issue was gone and never popped back up. I'm sure it will happen again and what makes me curious is if the dealer will consider this as an issue that can be covered even if I have passed my bumper to bumper warranty. The shifter was replaced once a couple of months back because the shifter button would get stuck. The car is still under warranty for engine and tranny issues.
Any updates?
Mike
Old May 15, 2011 | 08:41 PM
stevej88's Avatar
Re
Hey man, i had the shifter replaced three times, the last time they finally figured out it was a switch or bad relay switch i cant remember the exact cause but it wasnt the shifter module....... I wish i kept the paperwork but from all the research i did it all came down to a simPle fix
Hope this helps
Originally Posted by G3065
Hi everyone,
Any updates?
Mike
Old Jun 9, 2011 | 03:47 PM
G3065's Avatar
Thanks for the response brotha... Yeah I actually took it in immediately when it happened again without appointment. It took a day for them to fix the issue with no cost to me even though my general warranty had expired. They said the issue was electrical and the shifter assemb needed to be replaced. They were really helpful almost as much asyou guys .
Old Jun 19, 2011 | 09:23 PM
Holmes35's Avatar
I have this same problem at 75k miles....thanks for posting this info
Old Jun 19, 2011 | 10:36 PM
E-Ticket Ride's Avatar
I'll post the part number of the part they replaced for my car later
Old Jun 28, 2011 | 01:32 PM
Holmes35's Avatar
any update on the part number?
HOlmes
Old Jun 28, 2011 | 09:27 PM
I posted it in the other similar thread
Old Jun 29, 2011 | 01:05 AM
From my recent service:
"device assy-transmis 34901-JK60C," "replaced shifter assembly"
Old Jul 13, 2011 | 12:18 PM
Holmes35's Avatar
i'm confused reading this thread if i now need my shifter assembly replaced or not...it seemed like the other guy in this thread said it was an easy fix.....shifter assembly sounds expensive if i get the stealership to do it.
Old Jul 13, 2011 | 01:13 PM
Look up that part number in the FSM and see if it's something you can do yourself or not.
Old Jul 17, 2011 | 10:47 PM
eatsleepdrum's Avatar
Got my dealer to replace this. Along with many other things. Repost but FYI
Took my car in for a bunch of little problems the other day and got it back 2 days later from Grubbs on Airport. Told my service guy all of the problems I'd been having:
Steering wheel cracking/ warping
front left and right door trip chipping
manual shifter not downshifting in d/s mode
windows squeaking and rolling down slowly
headlights foggy
right door speaker rattle
here's what they did for me, it speaks for itself:
I've only had to take my car in for service a couple of times, but when I do Grubbs always takes care of me. No hassle or questions asked. +1 for them.
sam
Old Jun 5, 2012 | 02:44 PM
Viet2100's Avatar
So... Is it the shift assy or a relay? Mine just started doing this.
Old Jun 23, 2012 | 09:37 AM
  #30
terrycs's Avatar
It comes together as a complete shifter assembly.
arora_g35
Apr 16, 2026 02:52 PM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
Cskeet
Jul 21, 2015 05:48 PM
nervseele
Jul 17, 2015 11:21 PM
