Unable to shift into 5th
For all you 5AT 07+ G's out there here is a situation I just ran into and I am wondering if you all have experienced this yourselves.
When I am in M mode, I am able to shift 1 through 4 without a problem. When I try to shift from 4->5 my car will not shift gears. I was not in WOT during the shift and was going 45mph. I am wondering if it's just my car needs to "warm up" (I park it outside 100% of the time, it's cold as heck in IL, and this "problem" can only be replicated the first ~5 minutes from when I start the car up).
when in M mode there is a minimum speed you must be at before going to specific gears as same as on my tl.
Check your manual that should be the reason, next time around speed up a bit then try to go into 5th, im not familiar with the AT's shift pattern but i would guess 45 for 5th is about right but then again its a 5 speed gearbox so it might be higher
edwinisdumb15
SOCAL Meetings & Events
Sep 18, 2015 06:46 PM
