Serious Hesitation with Berks???
Old Mar 13, 2009 | 11:59 AM
ramo's Avatar
I just got my Berk HFC's put on this past weekend and today i finally got to open it up on the freeway on the way to work this morning. i noticed if I am cruising in 6th gear and the engine is revving between 2800 to 3000 and I step on it, the engine seriously hesitates until it gets over that 3000 mark and all of a sudden it accelerates. I did not disconnect my negative battery cable after, would that have anything to do with it learning?
Old Mar 13, 2009 | 12:55 PM
808MIKE's Avatar
Wow that's not good!! I just got my FI HFC's put on my car. I has that bad hesitation in the same RPM area in any gear! But mine was caused by a by a bad 02 sensor in the header! Which the dealer damaged during the install and replaced it free under warranty! After they changed that all my hesitation is gone so far I hope! Do u have any CEL showing? Since this cars ECU is so sensitive! Make sure there is no leaks in your exhaust at all! And if u have a CEL on, make sure u get the codes read to see what sensor is causing it. Or try reset ECU to see if that might help! Good luck bro!
Old Mar 13, 2009 | 01:04 PM
ramo's Avatar
No lights on in my dash
Old Mar 13, 2009 | 01:08 PM
ramo's Avatar
Whats the best way to reset the ECU?
Old Mar 13, 2009 | 01:16 PM
808MIKE's Avatar
I just disconnect the battery for like an hour. Or do the pedal reset. Not sure how that one works. Or do a search here for how to do it
Old Mar 13, 2009 | 02:19 PM
crazystand's Avatar
See this thread.
https://g35driver.com/forums/tech-07...eistation.html
Old Mar 13, 2009 | 02:28 PM
E-Ticket Ride's Avatar
Originally Posted by crazystand
ANMVQ had a 5AT while the OP has a 6MT. Similar but different.
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
alessandro
Oct 8, 2015 09:29 AM
Detailed Image
Sep 28, 2015 07:04 AM
Detailed Image
Sep 18, 2015 03:43 PM
bigmike
Sep 17, 2015 01:58 PM
